Old 08-28-2011, 05:32 PM
agnt549 agnt549 is offline
agnt549 is on a distinguished road
Default Haveing a on going issue
have a 03 H2 it runs fine when i first get it out and then when it gets hot i lose power i can have the gas pedal to the floor and only get like 1k rpm if i stay on it it will open up it does it on flat ground hills down hills ! have put new cats, muffler, throttle body, plugs & wires, coil packs nox sensors with plugs and radiator I'm at a lost HELP
Old 08-28-2011, 08:28 PM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
Default Re: Haveing a on going issue
fuel filter???
2004 Black H2
Old 08-29-2011, 03:05 AM
it's been replaced as well and it only does it when it gets hot
Old 08-29-2011, 11:34 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
I hope you find the problem as I am very curious what's causing this. I had a chevy truck that did the same thing, I never did resolve.
I checked everything, including dropping the tank and cleaning fuel lines.
My assumption was it was a vacuum line or maf. Never did get that far as I wound up trading it. Funny thing was it would run fine for about 100 miles after changing a fuel filter. So it ran good when traded...
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 08-29-2011, 04:05 PM
szmaters szmaters is offline
szmaters is on a distinguished road
not sure...but i had a similar problem with another veh. it was the ficm sensor
Old 09-25-2011, 05:17 PM
So i have a update / good news said F#!* the 1st dealerships toke it to anther dealerships it was there for 1day & half l got a call from them saying they found the issueS 1st one found wiring harness on left rear side had a short in it ,2nd one computer was Dead so yesterday i did a run with the H2 into the north back county of san diego HOLY bat man it ran up and down those hills like a bat out of hell i don't know if i said it but my H2 is a 180" limo
