Old 10-04-2011, 09:17 PM
Rockyot Rockyot is offline
Rockyot is off the scale
Default Amp Research Steps intermitant problem
anybody have an idea why my electric steps are now intermitant after a flawless 6 years?
Today is the best day you are going to get. Enjoy it and lift somebody up with you.
Old 10-04-2011, 10:39 PM
twr's Avatar
twr twr is offline
Default Re: Amp Research Steps intermitant problem
Hi here is a link to troubleshooting for the steps i hope it helps.
http://www.amp-research.com/?dl_id=51
http://www.amp-research.com/support/tech-support/
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 10-05-2011, 05:38 PM
[__--MUD--__]'s Avatar
well what the hell is it doing? No issue w/ mine, yet.
Old 10-05-2011, 07:29 PM
Open the door and step doesn't go down. Very random. When it is down close the door sometimes doesn't go up. Was just the right side now it's both sides randomly.
Old 10-06-2011, 05:46 PM
has there been any work done recently on your rig? stereo install?
Going off memory, each door has a signal tap going to it, wires running under the inner door sill/plate. If your marker lights or door seals are ****, that area fills up w/ water.
There really isn't much to these steps, You have a switch and a motor. Glancing through that troubleshooting doc they lay it out pretty good for you.
If you didn't install them yourself, there is a specific h2 install guide there also. Read over that first, then go over troubleshooting.
http://www.amp-research.com/products...-applications/
Use an electrical meter, test light wont verify proper voltage.
If your not sure on anything, let me know.
