Old 11-23-2011, 04:45 PM
HummerJim's Avatar
Default Lights
Anyone tried to replace their own light sensor? My headlights are always in the night mode, even in bright daylight.
Old 11-28-2011, 06:25 PM
vandy0090's Avatar
vandy0090 vandy0090 is offline
vandy0090 is on a distinguished road
Default Re: Lights
Shouldn't be hard....or its not rather. U will have to pull a lot of the dash to get to it
Pull the give box door off (3 screws bottom of the door)
Pull the cover on the pass side dash around the airbags (air bag stay installed)
There are 2 quick release push buttons to get the grab bar to slide off.
pull the AC vent panel on the drivers side and also the cluster housing panel
pull loose your center console panel(around the steroids/AC)
That gives you access to the screws that hold you forward dash panel on take all of them out and it slides aft. That sensor has a plug and about 1/4 of a turn and it comes off
It sounds like a lot but its not. Basically all the chrome hexhead screws
Good luck sir
