Old 01-25-2012, 10:53 PM
wrangedog wrangedog is offline
wrangedog is on a distinguished road
Default Replacing compressor and air springs on 2003 H2
I just ordered and received a replacement air ride suspension compressor from Arnott Inc. and replacement air springs from newgmparts.com. Just a quick question, Is this going to be as simple as merely swapping out the parts or am I going to need to go to the dealer to get everything reprogrammed, calibrated or at the least have the trouble code reset? Currently the compressor does not come on and the ride height button just flashes. The "service air suspension" is also displayed. The replacement compressor is the dual compressor as opposed to the original single. Thanks to all for any help.
Old 01-26-2012, 07:25 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Replacing compressor and air springs on 2003 H2
Disconect the battery ,install the parts, connect the battery and chances are it will work.
A government big enough to
you have.
-- Thomas Jefferson
Old 01-26-2012, 07:37 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
You will need to have the trim height set at the dealer or by someone who has a tech 2 scanner
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-26-2012, 07:44 PM
HUMTECH's Avatar
Also there are new airlines for the upgrade which they hopefully sent you. Did new compressor come with new control module? If not the single stage module will not work with the dual stage setup
1998 Chev Z71
Old 01-26-2012, 09:26 PM
Thanks guys, the compressor came with new lines, however I did not get the control module, which makes sense that i'll need.
Old 01-26-2012, 09:30 PM
Does anyone know if the control module for the updated dual compressor for an '03 is the same as a later model H2, like an '05 or so?
Old 01-27-2012, 04:31 AM
HUMTECH's Avatar
As far as i know all dual stage modules are the same. Also never try to have someone program one, one time write only and if you program it no longer will work. Okay to set trim heaight with tech 2 just cant do any software updates
1998 Chev Z71
