Old 06-10-2012, 02:46 PM
USMC_Buckaroo's Avatar
USMC_Buckaroo USMC_Buckaroo is offline
USMC_Buckaroo is on a distinguished road
Default Re: Best mods for money and performance
Originally Posted by jsbihn
Thanks guys!!
Great advice
Currently I am working on something right now to end the days of the H2's shifter linkage slipping.
I have a good cheap temporary fix in there now, using a nylon nut but the principle is still the same as OEM (just cost me 30 cents versus 125 dollars for a new assembly I dont need).
When I am done I should have a good permanent fix.
Howdy jsbihn,
I'd be interested in hearing more about this pard' (insert yellow smiley face holding its hand up to its ear )
Buck.
Old 06-10-2012, 03:43 PM
jsbihn jsbihn is offline
Moderator
Buck, I have the order in on the parts.
I have two coming just in case i botch one up since this is trial and error.
Hopefully this will permanently fix the problem, and I will never have to worry about the linkage slipping off since most likely it would break before this
Given, as of right now the nylon bolt with the nut clips has worked well. sure it is just a temporary fix since it will probably fail just like the oem since it is a form of plastic that will get to enjoy the heat of the transmission and exhaust before it gives out like the oem
Old 06-10-2012, 03:59 PM
Hellz Hellz is offline
Originally Posted by [__--MUD--__]
Call AGR Performance out of TX and tell them you want a high pressure pump w/ all the upgraded options.
can you provide a part # and what all options you bought on yours?
