Old 07-05-2012, 12:27 PM
SMITH23H2SUT's Avatar
SMITH23H2SUT SMITH23H2SUT is offline
SMITH23H2SUT is on a distinguished road
Default What is your "Dream Exhaust System". (Poll)
So it looks like I may have a broken exhaust manifold bolt causing a leak. I will be getting it fixed and will be doing a total swap out of the factory system for an Aftermarket upgrade.If you guys had free roam to get any components mix or match to build your system,what would you go with?What is your "Dream Exhaust Set-up"?
Old 07-05-2012, 04:49 PM
pdxrealtor's Avatar
Default Re: What is your "Dream Exhaust System". (Poll)
Long tube header (dynatech) with high flow cats and the quietest catback I could find.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 07-05-2012, 11:57 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
This I would agree with. These things are slow as hell so I've never quite understood the point of putting a loud exhaust on them but that's just my opinion.
Its always good to open the exhaust up and smooth out the junk factory bends with aftermarket parts but in our case keeping it quiet would be the best bet.
Old 07-06-2012, 12:00 AM
pdxrealtor's Avatar
You can say that again... I'm already starting to regret the Air Raid intake system....
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-06-2012, 01:31 AM
twinmill28 twinmill28 is offline
twinmill28 is on a distinguished road
http://www.autoanything.com/exhausts...3A3270872.aspx
This discussion has been ongoing in another forum, and one of the senior HUMMER members highly recommends the dynatech over the multitude of setups out there. He praises the quality of the set-up and says it actually improves torque and low end performance, which is what I'm looking for with my deuce towing a trailer.
If I understand it right, you can hook this system up to the factory exhaust, or do something more radical like the Corsa system, which is the route I'd love to go with the Dynatech.
Old 07-06-2012, 02:37 AM
Joe Joe is offline
Joe is off the scale
In the same boat, broken manifold bolt and looking at options.
Would love to go DynoTech and CAT Back but have been looking at OBX. So much cheaper and seems like a decent replacement. Anyone have experience with OBX?
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
Old 07-06-2012, 03:26 AM
VegasGuy's Avatar
VegasGuy VegasGuy is offline
VegasGuy is on a distinguished road
My dream exhaust set-up is one that doesn't cost any more than an OEM replacement and gets me 25 miles to the gallon.
Other than that, I would weigh the cost vs the potential gas savings. The one thing I would not sacrifice is the quiet ride.
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
Old 07-06-2012, 04:31 AM
pdxrealtor's Avatar
I think OBX has a different way of connecting the down pipes to mid pipes. It's like a ball type connection where as the DynaTech has flanged connections that are bolted. The flanged are a lot less likely to leak.
Not sure about anything else between the two.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-07-2012, 03:27 AM
jsbihn jsbihn is offline
Moderator
pdx,
I maybe wrong, but actually I thought I heard the ball socket flange was less likely to leak. That do to the design of the flange and the way it fits together, it seals itself. Where a regular flat flange setup is dependent on a gasket, and how many points on the flange are secured (ie. 2 bolt points, more area to possibly leak. 4 bolt points, less area to possibly leak)
Old 07-07-2012, 04:15 PM
pdxrealtor's Avatar
Originally Posted by jsbihn
pdx,
From a quick Google search it appears you're right.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 07-07-2012, 05:55 PM
Moderator
Well, we shall see which will be better. I might be buying headers too soon and if so, it will probably be the ones that work the best for the cheapest price.
If OBX are DynaTech copies (which alot of times I think OBX are copies of other well working headers. ie for M3 I think OBX or JVT copied the SuperSprint headers) I will go with them.
Old 07-08-2012, 12:16 AM
LoJac963's Avatar
OBX ARE in fact copies of more expensive headers. When I had my 06 GTO OBX had basically full copies of Kooks which were thousands of dollars. From what I've heard is the vette crews have had great success with OBX. If the vette guys are running them without issue they'll work on an H2. There were also a handfull of GTO guys running them also without issue.
Old 07-10-2012, 10:01 PM
Stellar Stellar is offline
Stellar is off the scale
Dynatech Long Tube Headers, straight pipe all the way back. Not really that loud IMO and even the wifey believes it fits the Hummer personality better.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
Old 07-15-2012, 06:37 PM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
Just got done doing Dynatech longtube headers, ceramic coated, Dynatech high flow cats, and through my Magnaflow muffler on there from my set up before. Sounds good, runs good, I like it. I'm not sure it sounds that drastic of a difference from the stock setup at all really, but does help with performance. Already running a CAI and chip too, so maybe that is why the changes are not as drastic, but power increases are felt.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 07-16-2012, 04:06 AM
pdxrealtor's Avatar
I know I posted above.... But Ive all but pulled the buy button on an obx long tube w cats setup. Curious what the cat back options are.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
