Old 07-17-2012, 02:01 AM
VegasMike VegasMike is offline
VegasMike is on a distinguished road
Default Re: A Couple Of Oddities...
Originally Posted by jsbihn
sounds like a programming glitch or possibly a short
given, do you remember if you turned the recirc off prior to shutting it down the last time, could be using the memory last function
I always leave it on because it blows harder with it on. I think it has more to do with other settings as mentioned above, and not an electrical issue.
With the 4X4 lights, I'm leaning towards either a switch with a intermitant short, or loose wire. Earlier today while sitting in a drive-thru when I had the stereo turned up, the beat of the music was making the neutral light flash. I pressed the 4HI and the light started blinking, then I got the service 4X4 notice on the dash. Shut off and restarted and it went back to normal.
