08-20-2012, 06:32 AM
H2 OBX Long Tube Header w/ High Flow Cat Install With Pictures
Ok.. Finally got these things installed and at 100%. Love the power gain, and can't wait to get a chip or tune. The low end grunt is finally there albeit nothing like a roots blower powered five liter mustang.
These tips and pics will help you with your long tube header install.
I got the OBX high flow cat system. With this system you will need the following additional items:
- 2 M18x1.5 short bolts or drain plugs. You'll plug extra O2 bung holes with these.
- 12 M8-1.25 x 30mm header bolts. I got mine from Fastenall M8-1.25 x 30mm DIN 6921 Class Class 90 Yellow Zinc Serrated Flange Bolt
- An EGR block off plate. Hummer H2 has no EGR to connect to the OBX header. Or you can do what I did.... read below.
- Spark plug wire heat shields or custom plug wires.
Soak for a few days with penetrating oil.. I used some CRC screw loose..
1) Put it on jack stands, ramps won't work. I tried it. Why? Because for the easy breezy removal/install you must remove your tires. Don't fight it, it's not worth it!
2) Remove your wheel well liners. Another must.
3) On passenger side remove the oil dipstick tube, 15mm socket. Remove the bolt. From below, through your awesome wide open access space, work the tube up and out of the hole. Drop a flanged bolt in the exposed hole- MAKE SURE IT's LARGER than the hole! Or use a rag, whatever. I used a bolt because it was non intrusive to other work or test drives.
4) Disconnect all spark plug wires at the spark plug and tuck them up out of the way. I think the only one I didn't have to disconnect was driver side front of engine.
5) Start removing those header bolts. Warm the engine up and then let it cool down a bit so it's just warm to the touch. This will help in bolt removal.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
08-20-2012, 06:57 AM
Re: H2 OBX Long Tube Header w/ High Flow Cat Install With Pictures
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-20-2012, 07:09 AM
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-20-2012, 07:26 AM
9) Alright... system is now removed. Like most people you now have broken bolts to deal with. These bolts are compliment of GM and they stick in your aluminum head. If you're lucky the stud is sticking out of the head. Use vice grips or a stud remover on a ratchet. If you're not lucky the bolt is inside the head. Couple of choices.... drill it and easy out it, or research ways to weld a nut on the bolt to ratchet it out with a socket.
I had one broken bolt, drive side closest to the firewall. There was a VERY nice stud sticking out and I just happened to remember I had this bad a*ss stud remover kit from Sears. AWESOME...right??  Ya.. it was awesome until I took two turns of the ratchet and the damn bolt snapped again.. YES.. again. A second time. So this one bolt snapped twice. Second time inside the head. Great. I was very fortunate to have a buddy over with more experience in this area than I.
We had to remove the fender well heat shield, use a drill bit with a hex end so it would fit in a socket. This socket was attached to 18" of 1/4" extension in order to reach the bolt on the head. I've heard people say right angle drill to get these busted bolts out.. I don't see it. No way.
My buddy drilled the perfect hole in this busted bolt, and then used his snap on extractor to back it out. Couldn't believe how great it turned out. Check out pics of the bolt. Two pieces... the one piece is the one I busted off with my stud remover (I was literally using the strength of my thumb!) the other piece is obviously the piece my buddy rock star drilled.
I don't have any pictures of the drill setup we used, but it's no different than the ratchet setup in other pics. A lot of length and a dead straight aim. To put in perspective the drill was outside of the fender well.
Old bolt next to new bolt - Fastenall M8-1.25 x 30mm DIN 6921 Class Class 90 Yellow Zinc Serrated Flange Bolt --- Thanks NJH2!!
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-20-2012, 07:41 AM
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-20-2012, 07:48 AM
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-20-2012, 07:49 AM
To be continued... I'm out of battery power.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-20-2012, 10:12 PM
awesome write up so far! The OBX's look awesome, they will definitely be a soon upgrade of mine before I get too many miles on those dang stock exhaust manis!
08-21-2012, 01:12 AM
agreed, awesome post that sure will come in handy in next few weeks. Thanks!
08-21-2012, 01:33 AM
12) Your cats and Y pipe are now all installed, but not tight. Start with your cats...rotate them so the O2s will screw in. On the driver side you'll see if you don't rotate the cats correctly your 02 sensor will be touching or very close to the front transfer case drive shaft. So plug that O2 sensor in, rotate your cat for the perfect position, then cinch up the cat to header connection. Obviously you want to tighten these three bolts evenly. Same thing on the other side. Make sure O2 sensor positioning is good to go and cinch the cat to header. You'll remove the O2 sensors after test fitting them, so you can get to the top bolt of the connection at the header/cat.
13) Now you'll have two sleeves mid Y pipe, and the connections at the muffler. Tighten both pipes at the muffler up, making sure your sleeve connections are nice and lined up first. This will allow for very easy final adjustments when you tighten the sleeves up.
You'll use the old bolts at the muffler end, so don't toss them when you take the old system out. FYI- I used a map gas torch to get the old connections loose at the muffler. Those were on good and rusted. The heat helped make it happen.
14) Now you have two more connection points mid way between the cats and muffler. One is on the cross over from driver to passenger side pipe, and the other is just after the passenger side cat. These connections are male/female so sliding the pipe in and out to the perfect line up is a piece of cake. Make your adjustments if needed, and tighten the sleeve bolts up. You might want to grab your tranny brush guard and make sure it fits, IE your exhaust is not hanging down to low. It shouldn't be an issue if you've lined everything up nicely.
These two pics show different angles of the O2 situation on the driver side
Y-pipe crossover sleeve. The sleeve on the passenger side is hidden by the crossmember
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-21-2012, 01:51 AM
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-21-2012, 02:09 AM
Last and the most costly mistake I made- plug wires.
17) Hook up your plug wires. On the driver side the middle two wires will route in a way that they not only touch the header, they push against the header. Now, this may be a 'no sh*t sherlock' type of deal, but not for me.  Since these wires were touching the pipes I wrapped them with the plastic heat shield. I have no idea what I was thinking, but I did it.. ok? It's done...lol. Learn from my mistake... or don't and treat yourself to a new set of spark plug wires.
18) Go to your auto parts store and get some heat tape. I got DEI brand. The heat tape was good. Didn't burn, mark up etc.... BUT it was letting heat through to the plug wire and that was making the plug boot at the coil pack to hot to touch. This is probably OK and you could call it done. I wanted to get a little more protection so I got some DEI wire/boot protectors. This keeps temps at the coil pack plug about 140*, 40* hotter than the other coil pack plugs. It also will prevent rubbing of the wire on the pipe. Another note... don't waste your money on header wrap just to wrap that one problem section. I did... and it turns out if you wrap just one section of the pipe it actually gets hotter. My header pipes are about 250* everywhere but where the header wrap is. There... it's 500*. It's coming off after I'm done with this wright up.  The heat tape and boot/wire protector is plenty.
This is what you have to deal with....
This is what happens if you do it wrong
I double wrapped, 2 layers, of the below pictured heat shield tape
Installed with just heat tape
Pic of the finished product. The section of header wrap, as mentioned, is coming off.
Products I used
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-21-2012, 02:20 AM
That's pretty much it. A side from the spark plug wire hiccup, not knowing the O2 bung hole plug size, and how I was going to plug the EGR port... it was a very smooth install.
Let me know if you have any questions on anything...
I can't wait to get a chip. Already there's a nice improvement but that chip should be the cherry on the top.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-21-2012, 06:18 PM
Excellent write up. Would love to hear a sound clip!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
08-21-2012, 06:29 PM
I'll put one on youtube when I have a moment.
I'm very happy with the sound. Can't really tell any difference unless you get on it.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-25-2012, 03:44 AM
Ahh man, I see what you are talking about now with the plug wires, that sucks! I will get a pic tomorrow on here of how mine ended up, but yah- that it nuts that they wrapped those things all around the plugs. Great post though, would you say the work was worth it for the sound and the extra boost?
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
08-25-2012, 04:15 AM
Ya weird how they upped that one pipe the way they did. A pic would be great.
This was well worth the money and the work. Even better was the intune chip I just bought. Really makes the truck shift entirely different.
Should have done the chip 1st thing. Without the chip the headers just don't operate like they should. For that matter, without the chip the truck doesn't operat like it should.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-27-2012, 04:19 AM
Here's a dynatech header link w some pics.
Compare......
http://www.elcovaforums.com/forums/s...342#post548342
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
08-27-2012, 04:26 AM
On another note...... The headers are nice, very nice, but without a chip youre missing out on what the headers offer.
I can't stress enough how important it is to get a chip and/or programmer after these mods.
I got the diablo sport inTune along with diablew tune (thx hellz for the referral) and with just the diablew 87 tune the truck was a new machine.
Currnently working with lew and I'm on the first tune. God damn.... TITS ... firm tits lol
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
