Old 08-31-2012, 01:56 AM
pdxrealtor's Avatar
Default Torsion bar removal
I need to remove my keys.
I read I can use a BJ press/c-clamp or a 2 jaw puller. I don't really feel comfortable using the puller. Barely feel comfortable using the c-clamp from a BJ press kit.
However, should I go the C-clamp route what is the procedure?
Lift front of truck up so wheels are off the ground. Jack stands.
Use c-clamp to lift key up just far enough to remove key bolt and keeper?
Then lower key by releasing c-clamp pressure?
I've never worked on anything automotive with such safety hazards so I'm a little shy here.
Any tips and direction would be awesome. I don't want to F myself up doing this ...
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 08-31-2012, 03:09 AM
H2ummer H2ummer is offline
H2ummer is an unknown quantity at this point
Default Re: Torsion bar removal
You have the gist of it. Lift the tires off the ground, jack stands for safety. Take the pressure off the bolt, remove bolt and keeper, remove clamp.
I used the actual tool made for this and was able to use my impact wrench with it. YMMV using a C Clamp as most do allow you to put a wrench on them. The BJ clamp may work.
The hardest part for me was getting the torsion bar out of the key. Lots of penetrating oil and impact chisel to break them apart. I off road mine and they were stuck together pretty well. I think that may be the hardest part for you.
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
Old 08-31-2012, 04:43 AM
pdxrealtor's Avatar
Thanks for your reply!
Got them out pretty easy and there didn't seem to be much load on them.
Once the keeper was out I took a sludge hammer and tapped the lower half of each key.....knocked them right off. Slid torsion bar forward and done deal.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 09-01-2012, 02:30 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
PDXrealtor, you swapping out the keys then?
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 09-01-2012, 05:49 AM
pdxrealtor's Avatar
Yes, possibly. Depends on what it looks like when I'm done. Might go right back to OEM.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 09-01-2012, 04:07 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
C-clamp will work, but this will work a hell of a lot better!
OTC 7822A GM torsion Bar Unloading tool
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
