Old 09-25-2012, 02:14 AM
h2con h2con is offline
h2con is on a distinguished road
Default Inside aspirator temperature sensor replacement
I have a over head aspirator temp sensor that has been buzzing for a bit and is getting louder. Has anyone changed one? I have a sunroof and am hoping it is possible to just drop the front drivers side corner of the headliner and replace the sensor?
Old 09-25-2012, 05:03 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Inside aspirator temperature sensor replacement
Yup, pop the grille off with a small flatblade. remove the a pillar trim panel. Use a skinny arm to reach under headliner and replace sensor. Usually end up with what looks like a rash on your arm cause its tight but is possible, done many that way
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-26-2012, 03:23 AM
Thank you. Going to order one and give it a wing.
