Old 02-02-2013, 02:47 PM
My08h2's Avatar
My08h2 My08h2 is offline
My08h2 is on a distinguished road
Question H2 Right hand side-mirror
Hi all,my right side mirror was cracked. Just wondering if anyone knows how to change just that??( not the whole thing,just the glass part ).
Thank you in advance!!!
Old 02-02-2013, 04:09 PM
Easy Ed Easy Ed is offline
Default Re: H2 Right hand side-mirror
I am pretty sure it is removed in the same manner as this video shows.
http://www.youtube.com/watch?v=kM3dj1RDaow
Another video http://www.youtube.com/watch?v=cMfrhqVfW8Q
Service manual does not show just the mirror glass replacement so I could not use it for reference.
HUMTECH may have more info on a "how to" if he sees this post.
Could not find a actual video for our H2's. Suggest that you move mirror to one side so you can see behind it to see if it is the same method. Also if you have heated mirrors use caution with the fluid inside the mirror cause it will damage the paint.
Good luck, Ed
Old 02-03-2013, 12:38 AM
My08h2's Avatar
Thank you very much!!!!!!!!!
Old 02-03-2013, 02:17 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Caution: Approved safety glasses and gloves should be worn when performing this procedure to reduce the chance of personal injury.
Notice: When servicing electrochromic glass that is broken, or if glass breaks during servicing, be cautious not to spill electrochromic fluid onto vehicle. Doing so will cause damage to the vehicle.
1. The top inboard corner is the ideal location for pulling the mirror out of the housing.
1. Remove the mirror face as follows:
2.1Push mirror glass bottom outboard (1) corner, furthest away from the vehicle door, as far as possible into the mirror housing.
2.2Place fingers tips behind the top inboard edge (2) corner, closest to the vehicle door.
2.3Pull the mirror glass with light pressure until the glass comes loose.
2.4Holding the mirror face, disconnect the electrical connectors from the back of the mirror.
Installation Procedure
1. Position the mirror face on a angle to the mirror housing.
1. Install the mirror face as follows:
2.1Holding the mirror face, connect the electrical connectors to the back of the mirror.
2.2Position the mirror face to the motor retainer tabs.
2.3Position the hand in the center of the mirror face.
2.4Apply light pressure to the face.
2.5Push downward and inward to lock in place.
2.6Inspect the mirror face for proper operation.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 02-03-2013, 02:27 AM
Thank HUMTECH for giving the correct instructions
Ed
Old 02-03-2013, 02:41 AM
HUMTECH's Avatar
Glad to help when i can
1998 Chev Z71
Old 02-04-2013, 07:49 AM
My08h2's Avatar
Thank you Humtech!!!!
Old 02-04-2013, 07:56 AM
My08h2's Avatar
Thanks so much guys!!! Just one last question,where can I buy that glass?? You guys think the one on e-bay is the right one?? http://www.ebay.com/itm/2003-2009-Hummer-H2-RH-Passenger-Side-Replacement-Mirror-SVR-1454-M2-/170975799302?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2008|Model%3AH2&hash=item27cef3a806&v xp=mtr
Thanks in advance!!!
