09-06-2005, 02:22 PM
So since we added the H3 to the family, I have not been able to program the homelink for both HUMMERS. I have the Homelink dialed in on the SUT, but when I program the H3, it doesn't work on the SUT anymore. If I set the H3 first and than the SUT, the H3 doesn't work anymore.
Anyone else have this issue?
09-06-2005, 02:36 PM
Try using different buttons. Seriously. And program them away from each other.
09-06-2005, 05:39 PM
Tried all the buttons (3 and 3 on both trucks). Also went as far as using different remotes. The dealer told me to drive one truck away and prgram the other one by itself. Didn't work either. Now I stumped!
Oh yeah, tried doing both at the same time too.
My neighbor now thinks I'm on drugs.
09-07-2005, 01:24 PM
sounds like you have a security feature that randomly changes. you should have a learning/training button or switch on the garage door opener itself, not the remotes. You will have to switch it on train/learn and then reset all ur remotes and homelink. Then program them all one, by one, while in this mode. they should all work after that.
09-07-2005, 02:21 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H2Singh:
sounds like you have a security feature that randomly changes. you should have a learning/training button or switch on the garage door opener itself, not the remotes. You will have to switch it on train/learn and then reset all ur remotes and homelink. Then program them all one, by one, while in this mode. they should all work after that. </div></BLOCKQUOTE>Yes, please tell us you were using the "learning" function on the opener motor. You dork.  I'll help when I get out there.
09-07-2005, 02:33 PM
Try calling the manufacturer of the garage door opener for suggestions.
09-07-2005, 08:35 PM
I use homelink in both the H2 and my toyota with no problems. They were both programmed using the learn button on the door opener. the only problem I've ever had is some openers allow for only 3 remotes to control it....so If you program a fourth, it deletes one of the others....
'03 H2
09-08-2005, 12:22 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by dochummer:
I use homelink in both the H2 and my toyota with no problems. They were both programmed using the learn button on the door opener. the only problem I've ever had is some openers allow for only 3 remotes to control it....so If you program a fourth, it deletes one of the others.... </div></BLOCKQUOTE>
I had the Nissan Z and the SUt programmed just fine and than when I brought the H3 home, it wouldn't work. The SUt would get deleted, but eh Nissan would be OK. So I have no idea. I just sold the Z, so I will try again with everything. maybe it only allows two to be programmed at one time.
09-08-2005, 05:06 AM
do you have a remote that came with the garage? That may count as one also. I know we went through something similar trying to get my parent's (sears brand - can't remember) opener programmed to my bro-in-law's remote and my homelink. It ended up deleting my father's homelink....If you have the manual, might want to check that...
'03 H2
