Old 09-25-2013, 04:36 PM
Ken Bowers Ken Bowers is offline
Ken Bowers is an unknown quantity at this point
Default Broken Steering cable nut
Yesterday, driving my orange H2, and suddenly I had no steering. It drifted off the road onto a sidewalk before I could stop. 2003 Hummer with 104,000 miles.
I was going about 25 mph when this happened. The tow truck driver says I have a broken steering cable nut that will have to be drilled out and replaced. The orange H2 is at the shop now.
So far, I have got out of this situation very lucky. All you guys should check your bolt.
Old 09-25-2013, 06:03 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: Broken Steering cable nut
any pics of this "cable"
Old 09-25-2013, 07:56 PM
No pics. Now they tell me it is a broken steering arm. $700.
Old 09-25-2013, 10:40 PM
LoJac963's Avatar
I was just curious as to where they think this cable is. Steering arm, are they talking Pitman arm or what?
Old 09-26-2013, 03:17 PM
UPDATE: I got my Orange Hummer H2 back yesterday, with a new steering arm.
The old arm was returned to me. It has a sheared pin, which is about 1/2 inch steel. I do not see how such a pin can shear off, and I suspect it was cut, or was defective when installed (2003).
The mechanic told me it could not have been cut, because it is unreachable when installed. How can it be unreachable, when it has a grease fitting?
This arm failed while I was stopped at a red light; there was no impact.
Three quarters of the pin surface is completely smooth, while the rest looks like a fracture would, with jagged projections.
Hey guys: any opinions as to what happened here?
Also-should you inspect your steering arm? I have 103,500 on my orange H2.
Old 09-26-2013, 06:36 PM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
Have a pic?
Is there a gap where you suspect it was cut? If no gap then I probably wouldn't give it a second thought.
It can be a pain to get the pitman out, therefore I highly doubt someone would remove it to cut it. Most likely manufacturing defect.
I'm surprised that you never changed the pitman since you've had the truck tbh, not that it should fail in such a way...
Old 09-26-2013, 07:12 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
If it was loose and rocking back and forth in the hole it will eventually wear and shear off. May want to double check for wear in the bore where the pitman arm goes through the steering linkage
1998 Chev Z71
2007 Chev Trailblazer SS
Old 11-01-2013, 03:18 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
I've never met a tow truck driver who thought cars are steered with a cable. Boats yes, cars no, at least not that I'm aware of. Anyway, that is a scary situation, good thing you were only going 25mph. Humtech's logic makes sense, but you should have noticed a lot of wandering or play I would think. Do you have yearly inspections in your state? I hate when they tell me it needs something, but I think I would hate it more to lose steering while driving.
Old 11-01-2013, 09:25 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Could it be the idler arm? There is a grease fitting on the top of the assembly that cannot be reached. This is the only grease fitting on the H2 that is inaccessable and he mentioned it.
