Old 03-29-2015, 08:41 PM
jsbihn jsbihn is offline
Moderator
Default Steering Question - Any way to tighten it up?
Hey all,
I am wondering if there is a way to reduces the "slop" in my steering?
Basically I am trying to reduce the amount of wiggle or movment in the steering wheel before it actually makes the wheels turn
Any ideas?
'03 H2 (name: Big Gulp)
Old 03-31-2015, 10:43 PM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Default Re: Steering Question - Any way to tighten it up?
No. Probably worn out staring gear box and should be replaced. I replaced mine on an '04 with the same symptoms and that fixed the slop in the steering. Now with my '06 I may be lose to the same repair with only 55k miles on this truck. It is leaking a small amount of fluid over time.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 04-25-2015, 06:47 PM
pdxrealtor's Avatar
^^ While that may be true, it's not the only thing that will fix sloppy steering. Pitman and idler arm would be the first thing I checked
There's actually a list of tests you can do for each front end component. Google 'test front end components' or similar for any chevy/GM.
I had horrible steering at 50k and while I replaced ball joints and hubs, I also replaced idler and pitman plus added the cognito support brackets- drives just like a brand new truck.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
