Old 12-27-2015, 02:11 AM
jsbihn jsbihn is offline
Moderator
Default headlights are out
Hey all
Well both my headlight went out simultaneously.
All the other lights work.... headlights no workie.
I looked at the switch and noticed it had a very light green light on (which if I remember correctly, when it was working correctly I think it was a bright orange light... but I could be wrong)
Anyone have any ideas?
Its 703 saturday night so of course I cant go out and fix this....
but right now my only thought is possibly a relay?
Also where would it be?
Also, could the passengers side floor board getting damp effect it? It rained here and it leaked and it made it down to the floor board and down to the hump the seat is on but no flooding or standing water, just the right side of the floor board on the passenger side.
Given they worked yesterday, and it rained like days ago....
'03 H2 (name: Big Gulp)
Old 12-29-2015, 01:42 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Default Re: headlights are out
I would check the fuse first then the relay next. The light on the stalk inside is on a different circuit.
Old 12-29-2015, 02:03 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Have you done the drl modification in the fuse block that many guys do? If so I would be looking there first. Seen many internal fuse block failures due to this.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 12-30-2015, 01:19 PM
Moderator
Tech did do the DRL mod, do thanks for the heads up.
it was the relay. swapped and it was fixed
thanks
just was a wickedly bad experience. pitch black out and I am out running a med call and all of a sudden the headlights go out on the way home. now I am navigating home by starlight.
Old 01-04-2016, 05:20 PM
What are you seeing that the DRL mod is causing?
Old 01-05-2016, 01:01 AM
HUMTECH's Avatar
The mod I was reffering to was if you power up the drl relay with the headlight relay signal so all 4 lights are on at the same time puts more draw on the headlight circuit, not to mention some peoples wiring skills can be sub-par and also cause issues. That's why I always look at electrical modifications prior to anything else.
1998 Chev Z71
