Old 01-16-2004, 08:14 PM
OK, I had one crack repaired under warranty and now have 2 more. Hummer is sending me a new hood under warranty but it appears this is just going to continue. Is there any way to stop this or is it part of owning a truck with a fiberglass hood.
Yes, I offroad frequently and bounce the piss out of it.
Old 01-17-2004, 12:16 AM
Axleman Axleman is offline
Axleman is off the scale
I think you have answered your own question.
Scot Smith
1994 HMC4
"They're right, Wider IS Better..."
Scot Smith
1994 HMC4, Locked
Steering & Axle Express
Steering, Driveline & other Hummer Stuff
Old 05-13-2004, 10:37 PM
Yetti Yetti is offline
I was wondering , are the GM folks going to let you keep the old hood? if so then rig a lift in your garage to swap them out from off road hood to daily driver hood.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 06-23-2004, 12:25 PM
Arizona Hummerboy's Avatar
Buckeye, take the hood off when you off road and you wont have that problem.
Old 08-03-2004, 05:50 PM
It\'s a Dry Heat's Avatar
You beat me to it Hummer Boy.
Serious... Learn how to do fiberglass work. reinforce that area. - its not that hard, stop drill the cracks and paint a design in that area. Do this on one of your old hoods. Then when you fixed it - sale the idea back to GM.
