02-25-2006, 10:52 PM
I can feel a vibe through the steering wheel and also feel it in the floor board. It is when cruising. When turning or under strain, it goes away. I've taken a quick look at the ujoints in the front driveshaft and have looked at the front drive axle shafts , everything seems fairly tight. Is there any common problem out there like wheel bearing failure or carrier bearings in front diff. Cant seem to pin point where the vibration is coming from , but its getting pretty bad. Thanks , Doug
02-25-2006, 11:51 PM
Could be steel belt in tire out of place. Lift vehical spin wheel looking straight on at it. Just a thought.
02-26-2006, 12:38 AM
Doug,
Do you have any mud caked in the inside of the wheels? It could be simple like that - causing wheel vibe.
Do you have a bent wheel?
You probably already checked all this - but I thought I would toss it out.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
02-26-2006, 01:48 AM
I have pretty new tires on front prolly about 10,000 miles on them. I will check for mud caked in wheel. But it sounds and feels a little metallic. . Doug
02-26-2006, 01:56 AM
If is it not that - check the wheel bearings - it does sound like it might be that - but how many miles do you have?
02-26-2006, 02:15 AM
88K ? +/-
02-26-2006, 02:18 AM
hmmm...could be. Probably a tech would know more, but it might be a wheel bearing.
02-26-2006, 02:27 AM
Thanks, i'm going to tear into it a little tommorrow. Its bugging me i cant find the problem.
02-26-2006, 05:49 PM
Got it inside today and thawed out. Problem was the drivers side wheel bearing. Thanks for the help. Does anyone know if the wheel bearing comes as a assymbley or can i press the bearing and save some money??
02-26-2006, 05:57 PM
Heres a pic of the wheel bearing in the hub assy. , i have a bearing separator on it to put it in the press and take the bearing out. But i dont want to go through that if it comes from hummer and is cheap. does anyone know the price of the assy? thanks
02-26-2006, 05:58 PM
nuther pic
02-26-2006, 06:19 PM
Just saw a used wheel bearing assy . on ebay for $85. Guess its prolly not going to be to expensive for a new one. Find out monday.
02-26-2006, 06:23 PM
02-26-2006, 09:32 PM
yes Phil , the front bearing is a timken . I'm going to press it apart and see if i can replace the bearing only. I dont see any need to waste all the other parts.
06-10-2010, 01:17 AM
Re: Front end vibration?????
