04-08-2006, 01:58 AM
does anybody know the best place to purchase a thermostat switch or theremostat i cant seem to find one for the 2005 thanks
04-08-2006, 02:04 AM
Maryland
04-08-2006, 02:22 AM
Originally posted by PARAGON:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MONSTERMATT:
Maryland </div></BLOCKQUOTE>
Hey Paragon,
That's funny even for you... LOL.
Seriously Matt, you'll probably have to order one from a speed shop (eg. Summit, etc) I highly doubt you'll be able to run down to your local AutoZone and pick one up.
Had the same problem on my past vehicles when I wanted to drop down.
Mark
04-08-2006, 02:36 AM
Try the marine eng. parts house , boat engs. run about 160. To keek the saltwater from crystalizing .
04-08-2006, 02:50 AM
I got mine from Lingenfelter, fast!
04-08-2006, 03:08 AM
You might mean the 180 degree performance stat. I wouldn't go lower than that. Stock is 195. http://www.mossh2.com/Shop/SearchResults.aspx?SearchTex...9-405&WebCatalogID=0
04-08-2006, 04:03 PM
UH OH, i just ordered one from rpmoutlet online and it is a 160 degree made for the h2 wonder if i should still give it a go, i remember phil d runs a 160 i think
04-08-2006, 10:09 PM
Yeah, but Phil lives in Texas
04-09-2006, 01:05 AM
SOO, u think the 160 will or could cause trouble? if so what would it be, i just cant believe the 20 dgrees would make that much of a difference, any and all feedback is much appreciated, and it does get pretty hot in maryland in the summer, thanks
04-09-2006, 01:07 AM
If I lived in Maryland, I would definitely go with the 180.
What all does your engine have on it and what are you trying to achieve by lowering the therm temp?
04-09-2006, 04:29 AM
yes it's cool because the temp is smaller really bro. Phl did that too and had to do sum other stuf. Guud luk with your tuf progect.
04-09-2006, 07:48 PM
Just out of curiousity, will the stock cooling system even handle a 160 thermostat? I mean, it doesn't matter what degree your thermostat is if the entire system won't hold it.... it'll just make the thermostat stay open all the time.
Mark
04-09-2006, 08:59 PM
sales@lingenfelter.com
Lingenfelter should be able to provide you with a 160 t-stat.
phone.260.724.2552
As others have asked, what is your reason for wanting the 160?
I can tell you that if you're trying to ward off a run hot issue the t-stat alone isn't going to solve your problem.
A larger radiator will help.
Personally I'd stay away from aluminum radiators. In my continuing efforts to solve my own heating problems I've discovered that aluminum radiators are not meant to be in a daily driver. They were/are built for racing applications and are expected to be treated as a disposable commodity being replaced every couple of races.
As for what trouble will a 160 cause? Probably none other than as Mark has stated it will remain open most of the time. In your winter months you may have to let the truck run in the driveway for a bit longer until it gets up to operating temp.
04-10-2006, 08:55 PM
In the hotter states, a 160 deg t-stat is marginal as far as damaging o2 sensors and catalytic convertors. I'd say the 180 deg would be a better bet in your climate. If you're running straight pipe exhaust, go with the 160 deg definitely.
04-10-2006, 10:54 PM
I run a 185F t-stat and it made absolutely no difference. The engine temp still gets up to 200-210F under normal conditions
That is because the cooling is marginally big enough for the heat load that is placed upon it. The BTUs that the radiator can reject just about equalls the heat load from the engine and transmission.
Going to a lower temp t-stat will only slow warmup time in cooler weather. This will cause the eng to run in an enriched mode just that much longer- until it get up to proper operating temp.
Contrary to popular belief only lowering the temp of the coolant by going to lower thermostat does NOT reject more heat from the engine. It only reduces the amount of heat that is transfered from the eng block to the coolant.
The only way you will effectivly get a lower operating temp is to reduce the heat load (like looping out the trans cooler) or go to a larger cooling system/radiator that can reject more heat.
I looped out my trans cooler in the rad. tank and went to a larger T-cooler in front of the radiator. Now my coolant temp hasn't gone above 195F. with a 195 t-stat on the hardest pulls. That is becaus I removed the heat that was being added to the coolant from the trans.
04-11-2006, 08:58 PM
Hummie2 is way smarter than me!
. . .But Matt is dumber than a sack full of hammers!
Remind me again how you managed to aquire this truck when you struggle to compose a sentence!
Matt + English = !Poette uhlitterut;? No pictures yet huh Chaucer?
04-12-2006, 05:03 PM
longhorn owes me ten bucks, what a CHUMP
04-12-2006, 05:48 PM
You never came with the pictures. My original offer had a timeline.
I know, I know digital cameras are awful tough to operate there Corky.
