Old 03-31-2004, 11:19 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
I took my H2 in to the dealer for a bunch of other minor things, and was told that the auto volume only adjust the bass in the vehicle when the interior noise level goes up or down. It is not speed dependent. There was supposively a tech report on this. Does anyone have any info on this, or is the dealer full of it?
Thanks,
Ric-H2
www.meatspin.com
RIC-H0's Avatar
Thanks,
Ric-H2
www.meatspin.com
Old 03-31-2004, 11:25 PM
Anthony Anthony is offline
Anthony is an unknown quantity at this point
I don't have technical info, but can tell you it sounds like the highs and mids get louder in addition to the lows. I don't know if it is speed sensitive however, it seems to me it only gets louder when I get on the highway.
Old 04-01-2004, 12:13 AM
cinci cinci is offline
cinci is off the scale
Anthony,
Are you implying that your auto volume works? If so you are the first person to post on here that it actually works.
Ric,
I do believe that it is supposed to be the full spectrum not just the base. I believe your dealer is blowing smoke .
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
Anthony,
Ric,
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
Old 04-01-2004, 12:33 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by RIC-H2:
It is not speed dependent. There was supposively a tech report on this. <HR></BLOCKQUOTE>
What in the f*ck is supposively?
I think we've all heard the poor word, supposedly, butchered into supposebly, and Ebonically as stupposibly, but supposively is really scraping the bottom of the ****ty spelling barrel. Damn.
Old 04-01-2004, 12:11 PM
sbmike's Avatar
sbmike sbmike is offline
sbmike is off the scale
I took mine into the dealer for the same thing and was told it is working fine. I have yet to hear any difference in volume whatsoever. It was very evident on the radio in my Avalanche.
04 Yellow Lux with Adv stuff like air suspension and full brush guard.
sbmike's Avatar
Old 04-02-2004, 12:10 AM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="Microsoft FrontPage 5.0" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1236781
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Radio Automatic Volume Control Feature Inoperative (Rewire Noise
Cancellation Microphone) #03-08-44-004 - (02/04/2003)</H1>Radio Automatic Volume
Control Feature Inoperative (Rewire Noise Cancellation Microphone)
2003 HUMMER H2</P><A name=ss1-1236781><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1236781&psdid=293&evc=sm#ss1-1236781">
<H5>Condition</A></H5>
Some customers may comment that the Automatic Volume Control feature of the
radio is not working.</P><A name=ss2-1236781><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1236781&psdid=293&evc=sm#ss2-1236781">
<H5>Cause</A></H5>
The wires to the noise cancellation microphone may be installed in the
incorrect cavities at the audio amplifier module.</P><A name=ss3-1236781><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1236781&psdid=293&evc=sm#ss3-1236781">
<H5>Correction</A></H5>
Install the noise cancellation microphone wires into the correct cavities at
the audio amplifier module using the following procedure:</P>
  1. <LI type=1>Remove the center console in order to gain access to the audio
    amplifier module. Refer to the Console Replacement procedure in SI (Document
    ID #834656).
    <LI type=1>Disconnect connector 1 (Light Gray, 24 way) from the audio
    amplifier.
    <LI type=1>Locate the two wires (circuit 1354, Light Green/Black and circuit
    1488, Dark Green) in the connector for the noise cancellation microphone. They
    are in cavities B1 and B2 of the connector.
    <LI type=1>Remove the two wires from the connector and reinstall them into the
    opposite cavity from where they were originally. The Light Green/Black
    (circuit 1354) wire should now be installed in cavity B1. The Dark Green
    (circuit 1488) wire should now be installed in cavity B2.
    <LI type=1>Reconnect connector 1 to the audio amplifier module.
    <LI type=1>Install the center console. Refer to the Console Replacement
    procedure in SI (Document ID #834656).
    <LI type=1>Verify the operation of the noise cancellation microphone and the
    Automatic Control Feature of the Entertainment System.
    <LI type=1>If the Automatic Volume Control is still inoperative, refer to the
    Diagnostic Starting Point-Entertainment (Document ID #684715) for further
    diagnosis. </LI>
<A name=ss4-1236781><A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1236781&psdid=293&evc=sm#ss4-1236781">
<H5>Warranty Information</A></H5>
For vehicles repaired under warranty, use:</P>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
Labor Operation</P></TH>
Description</P></TH>
Labor Time</P></TH></TR>
<TR>
<TD vAlign=center align=middle>
N6632</P></TD>
Wiring And/Or Connector-Repair Or Replace-Vehicle Entertainment</P></TD>
ST</P></TD></TR></TBODY></TABLE>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved.
</P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Klaus's Avatar
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<H5>Cause</A></H5>
    ID #834656).
    amplifier.
    diagnosis. </LI>
<TBODY>
<TR>
<TR>
N6632</P></TD>
</P>
<TBODY>
<TR>
the information.
</FONT></TD>
CERTIFICATION
Reserved.
</P>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Old 04-02-2004, 12:12 AM
Klaus's Avatar
<TBODY>
<TR>
<TD align=middle width="50%">Document ID# 1369904
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<H1>Noise Compensated Volume Inoperative</H1>
<TBODY>
<TR>
Step</P></TH>
Action</P></TH>
<TH align=middle>
Value</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
<TD vAlign=bottom align=left colSpan=5>
Schematic Reference: <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=46762&RefDoc=1369904">Radio/Audio
System Schematics</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S01>
1</P></A></TD>
<TD vAlign=top align=left>
Did you perform the Diagnostic System Check - Entertainment
System?</P></TD>
--</P></TD>
<TD vAlign=bottom align=middle>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S02"> Step
2</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=66419&RefDoc=1369904">Diagnosti c
System Check - Entertainment System</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S02>
2</P></A></TD>
  1. <LI type=1>Turn ON the ignition, with the engine ON.
    <LI type=1>Turn ON the blower motor on the maximum speed.
    <LI type=1>Cycle the auto volume control ON and then OFF. </LI>
Is a difference in volume heard?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62112&RefDoc=1369904">Testing
for Intermittent and Poor Connections</A> in Wiring Systems</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S03"> Step
3</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S03>
3</P></A></TD>
  1. <LI type=1>Turn ON the ignition, with the engine OFF.
    <LI type=1>Disconnect the noise compensation microphone.
    <LI type=1>Measure the voltage from the noise compensation microphone
    supply voltage circuit to the drain wire. </LI>
Does the voltage measure near the specified value?</P></TD>
8V</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S04"> Step
4</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S05"> Step
5</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S04>
4</P></A></TD>
Replace the noise compensation microphone. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=47020&RefDoc=1369904">Microphon e
Replacement - Radio Volume Compensator Interior</A> .</P>
Did you complete the replacement?</P></TD>
--</P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S09"> Step
9</A> </P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S05>
5</P></A></TD>
<TD>
Test the noise compensation microphone supply voltage circuit for an
open or short. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62194&RefDoc=1369904">Circuit
Testing</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61965&RefDoc=1369904">Wiring
Repairs</A> in Wiring Systems.</P>
Did you find and correct the condition?</P></TD>
--</P></TD>
Go to <A
9</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S06"> Step
6</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S06>
6</P></A></TD>
<TD>
Test the drain wire circuit for an open or short. Refer to <A
Testing</A> and <A
--</P></TD>
Go to <A
9</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S07"> Step
7</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S07>
7</P></A></TD>
<TD>
Inspect for poor connections at the amplifier. Refer to <A
for Intermittent and Poor Connections</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61973&RefDoc=1369904">Connector
--</P></TD>
Go to <A
9</A> </P></TD>
Go to <A
href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=1369904&psdid=293&evc=sm#S08"> Step
8</A> </P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S08>
8</P></A></TD>
<TD>
Replace the amplifier. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=46705&RefDoc=1369904">Amplifier
Replacement</A> .</P>
Did you complete the repair?</P></TD>
--</P></TD>
Go to <A
9</A> </P></TD>
--</P></TD></TR>
<TR>
<TD vAlign=center align=middle><A name=S09>
9</P></A></TD>
Operate the system in order to verify the repair.</P>
Did you correct the condition?</P></TD>
--</P></TD>
System OK</P></TD>
Go to <A
3</A> </P></TD></TR></TBODY></TABLE>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Klaus's Avatar
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<HR>
</FORM>
<TBODY>
<TR>
Step</P></TH>
Action</P></TH>
<TH align=middle>
Value</P></TH>
Yes</P></TH>
No</P></TH></TR>
<TR>
<TR>
1</P></A></TD>
System?</P></TD>
--</P></TD>
Go to <A
2</A> </P></TD>
Go to <A
<TR>
2</P></A></TD>
--</P></TD>
Go to <A
Go to <A
<TR>
3</P></A></TD>
8V</P></TD>
Go to <A
4</A> </P></TD>
Go to <A
<TR>
4</P></A></TD>
--</P></TD>
Go to <A
9</A> </P></TD>
--</P></TD></TR>
<TR>
5</P></A></TD>
<TD>
Testing</A> and <A
--</P></TD>
Go to <A
9</A> </P></TD>
Go to <A
<TR>
6</P></A></TD>
<TD>
Testing</A> and <A
--</P></TD>
Go to <A
9</A> </P></TD>
Go to <A
<TR>
7</P></A></TD>
<TD>
--</P></TD>
Go to <A
9</A> </P></TD>
Go to <A
<TR>
8</P></A></TD>
<TD>
--</P></TD>
Go to <A
9</A> </P></TD>
--</P></TD></TR>
<TR>
9</P></A></TD>
--</P></TD>
System OK</P></TD>
Go to <A
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
Old 04-03-2004, 12:41 AM
OldHiker OldHiker is offline
Mine is definitely working. It seems the faster I drive (to a point) the louder it gets. Makes sense. More road noise at higher speeds then tooling around at 20mph.
Old 04-04-2004, 04:43 PM
RIC-H0's Avatar
What in the f*ck is _supposively_?
I think we've all heard the poor word, supposedly, butchered into supposebly, and Ebonically as stupposibly, but supposively is really scraping the bottom of the ****ty spelling barrel. Damn. <HR></BLOCKQUOTE>
Alright Mr. Webster. If I wanted a grammer lesson, I would ask my 14 year old daughter. I'm here to ask for advice, not to re-take the 5th grade. Go teach someone else!
Ric-H2
www.meatspin.com
RIC-H0's Avatar
Ric-H2
www.meatspin.com
Old 04-05-2004, 01:06 PM
Cinci,
Yeah ours works. Was in it yesterday and it did get louder- not just the bass.
Cinci,
