Old 09-14-2005, 07:56 PM
Make sure your dealer has performed the prescribed additional fill of your transfer case fluid. Mine didn't, so it is going back in for the additional fill.
Old 09-14-2005, 08:11 PM
richk richk is offline
richk is off the scale
Do you have a service bulliten number or something that I can provide to the dealer for reference?
2006 H3, Adventure Package, Sunroof, Brush Guard, Tube Steps, XM Radio, Shadow Green Metallic
Old 09-14-2005, 08:41 PM
Ok f5fstop....I don't know how to read the number...I can tell you numerically speaking it is a definitely lower (smaller) than the one posted.
help
Old 09-14-2005, 09:03 PM
goose's Avatar
goose goose is offline
goose is off the scale
is it related to the whining noise in the powertrain? need to check my number ... i got my H3 three monthe ago
anyway thanks for the update f5fstop
2006 Black SUT
Old 09-14-2005, 10:05 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummBeebe:
help </div></BLOCKQUOTE>
Just the last five digits are all that is required, that is actually the VIN sequence number.
This is a VIN breakdown for GM light trucks, different than used for Cars or Medium Duty Trucks.
5 Country of Build (1,4,5 denote USA)
G World Make Modifier G = Hummer
T H3
D GVWR/Brake System D = 5001-6000 GVWR Range (lbs) Hydraulic brakes
N Line Chassis N = Hummer
1 Series 1 - 4x4
3 Body Type 3 = Four-door cab/utility
6 Engine Type 6 = L52, 3.5L L5, MFI
9 Check digit (randomly generated)
6 Model Year 6 = 2006
8 Manufacturing Plant 8 = Shreveport, LA
105387 VIN Sequence number. First digit (1) is not used on this vehicle for VIN range and may change from year-to-year. For example, one year it might be 1, the following year 5. If the plant will produce greater than 99,999 vehicles it will be used and wil be zero until the 100,000 vehicle is produced. In this case, this vehicle was the 5,387 H3 to be issued a VIN.
Old 09-14-2005, 10:27 PM
Phew!!! not me
Old 09-14-2005, 11:20 PM
woyster_h3 woyster_h3 is offline
woyster_h3 is off the scale
105835 here...guess I'm OK.
Traded 4-1-06: 2006 Black Hummer H3 Adventure Series - Vortec 3.5L Inline 5
Offroad Suspension Package, 33" Tires, Electronic Fully Locking Differential, 4.03:1 2-speed Transfer Case, Ebony Cloth Trim, Automatic Transmission, Sunroof, Roof Marker Lamps, Fog Lamps, XM Satellite Radio, CD/MP3 Player, Trailering Package, Black Tube Nerf Bars
Old 09-14-2005, 11:36 PM
Sharkster's Avatar
Sharkster Sharkster is offline
Sharkster is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">In this case, this vehicle was the 5,387 H3 to </div></BLOCKQUOTE>Mine is in the 4,000s but I don't have any probs with my H3 whatsoever (2,500 miles so far). Am I supposed to have my transfer case fluid checked now? There's no official HUMMER dealer here in Germany... so if I want my garage to check the transfer case fluid, will they know how to do it (i.e. is it an easy procedure?).
Old 09-14-2005, 11:52 PM
H3ProspectKy's Avatar
H3ProspectKy H3ProspectKy is offline
H3ProspectKy is off the scale
28108 here (assigned end of July), wow...quite a few built so far.
Old 09-14-2005, 11:59 PM
h3\'er h3\'er is offline
h3\'er is off the scale
wow I got a young un 0249 here
Old 09-15-2005, 12:04 AM
DeLeon DeLeon is offline
DeLeon is off the scale
Mine is 2010, but I haven't had any issues with the trans.. called the dealer and they said they don't know anything about this... what else can I tell them, is there going to be a recall or..??
\'06 Boulder Gray H3 / Loaded
Old 09-15-2005, 12:14 AM
H3OH H3OH is offline
H3OH is off the scale
Mine is 11864, so I guess I'm safe.
\"In the poker game of life, women are the rake man. They are the f$#@%n\' rake.\"
__________________________________________________ _____________________
\'06 H3 - Birch White, Auto, Lux Pack (with Homelink), Chrome Pack (with Crossbows), Chrom
Old 09-15-2005, 12:58 AM
Tones H3 Tones H3 is offline
Tones H3 is off the scale
uh what the heck is this about?
Old 09-15-2005, 06:44 AM
wannabeH3's Avatar
103259 guess i better check it out
(with insurance)
Old 09-15-2005, 07:44 AM
All required have received private topic emails.
Old 09-20-2005, 01:25 AM
Hi-Cap Hummer Hi-Cap Hummer is offline
Hi-Cap Hummer is off the scale
Owners manual supplement, "Filling the transfer case to the drain fill plug is no longer adequate. You need to add 0.25L (8.5 ounces) after you fill to fill plug. Install fill plug and add 0.25L through speed sensor hole per instructions on bottom of transfer case.
Another way I used is to jack up the drivers side and air down to 12 lb on passenger side of vehicle. This raises the fill plug in relation to the drain plug, I was able to add 0.25L ATF.
Since the transfer case only holds 1.6 qt, I changed it to Mobil 1 Synthetic ATF, approved for H Specification. Since I do it myself, only the best for the H3.
Old 09-20-2005, 07:40 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hi-Cap Hummer:
Since the transfer case only holds 1.6 qt, I changed it to Mobil 1 Synthetic ATF, approved for H Specification. Since I do it myself, only the best for the H3. </div></BLOCKQUOTE>
5 minutes to remove speed sensor, add fluid and re-install versus how long to jack up vehicle, deflate/inflate tires?
Old 09-20-2005, 12:20 PM
Webb70 Webb70 is offline
Webb70 is off the scale
All required have received private topic emails. </div></BLOCKQUOTE>
Mine is 2247.
Old 09-20-2005, 02:03 PM
HummerJim's Avatar
Wow, H3'er you might be low VIN man. Got mine in June and it's 0389. After my water adventures, I have already changed all my fluids, except for the transmission.
