Old 02-21-2005, 04:18 PM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2900.2604" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"></TD>
<TD align=middle width="50%">Document ID# 1580377
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM>
<HR>
</FORM>
<H1>Clunk, Bump or Squawk when Vehicle Comes to Complete Stop or Accelerating
from Complete Stop or Accelerating from Complete Stop (Replace Rear Drive Shaft
Nickel-Plated Slip Yoke) #01-04-17-004B - (Jan 5, 2005)</H1></TABLE>Clunk, Bump
or Squawk when Vehicle Comes to Complete Stop or Accelerating from Complete Stop
(Replace Rear Drive Shaft Nickel-Plated Slip Yoke)
1999-2000 Cadillac Escalade (Old Style)</P>
2002-2004 Cadillac Escalade, Escalade EXT</P>
2003-2004 Cadillac Escalade ESV</P>
1996-1999 Chevrolet 1500 Series Extended Cab Short Box Pickup (Old Style)</P>
1996-1999 Chevrolet 1500 Series Regular Cab Pickup and Utility Models (Old
Style)</P>
1999-2002 Chevrolet Silverado Extended Cab Short Box (New Style)</P>
1999-2004 Chevrolet Silverado 1500 Series Regular Cab (New Style)</P>
2000-2004 Chevrolet 1500 Series Avalanche, Suburban and Tahoe</P>
2001-2004 Chevrolet Silverado 2500/3500 Series Regular Cab with Long Bed or
Extended Cab (New Style)</P>
2001-2004 Chevrolet Silverado 2500 Series Crew Cab, Short Box (New Style)</P>
1996-1999 GMC 1500 Series Extended Cab Short Box Pickup (Old Style)</P>
1996-1999 GMC 1500 Series Regular Cab Pickup and Utility Models (Old
Style)</P>
1999-2002 GMC Sierra Extended Cab Short Box (New Style)</P>
1999-2004 GMC Sierra 1500 Series Regular Cab (New Style)</P>
2000-2004 GMC 1500 Series Yukon, Yukon XL</P>
2001-2004 GMC Sierra 2500/3500 Series Regular Cab with Long Bed or Extended
Cab (New Style)</P>
2001-2004 GMC Sierra 2500 Series Crew Cab, Short Box (New Style)</P>
2003-2005 HUMMER H2</P>
with Four Wheel Drive (4WD) or All Wheel Drive (AWD) and One-Piece Propeller
Shaft ONLY</P>
This bulletin is being revised to add Cadillac Escalade (Old Style) and
HUMMER H2 to the Models section. Please discard Corporate Bulletin Number
01-04-17-004A (Section 04 -- Driveline/Axle).</P><A name=ss1-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&pubid=293&evc=sm#ss1-1580377">
<H5>Condition</A></H5>
Some customers may comment on a clunk, bump or squawk noise when the vehicle
comes to a stop or when accelerating from a complete stop.</P><A
name=ss2-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&pubid=293&evc=sm#ss2-1580377">
<H5>Cause</A></H5>
A slip/stick condition between the transfer case output shaft and the
driveshaft slip yoke may cause this condition.</P><A name=ss3-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&pubid=293&evc=sm#ss3-1580377">
<H5>Diagnostic Tips</A></H5>
There are several resources in the electronic Service Information System
which can provide the technician with information on diagnosis and repair of
clunk conditions, and fix the customer's vehicle right the first time without
unnecessary parts replacement. Some of the documents available in SI
include:</P>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top><FONT size=4>•</FONT></TD>
<TD vAlign=top>Symptoms - Propeller Shaft (SI Document ID #697266)
</TD></TR></TBODY></TABLE></DIV>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Knock or Clunk Noise (SI Document ID #697290)
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Rear Drive Axle Noises (SI Document ID #700580)
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Launch Shudder/Vibration on Acceleration (Replace Propeller
Shaft and Install a New Pinion Flange/Seal), Bulletin #02-04-17-001
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Information on 2-3 Upshift or 3-2 Downshift Clunk Noise,
Bulletin #01-07-30-042 </TD></TR></TBODY></TABLE></DIV>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<TD vAlign=top>Driveline Clunk When Stopping (Reprogram Powertrain Control
Module (PCM), Bulletin #03-07-30-028 </TD></TR></TBODY></TABLE></DIV><A
name=ss4-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&pubid=293&evc=sm#ss4-1580377">
<H5>Correction</A></H5>
Replace the rear drive shaft slip yoke with a new nickel-plated slip yoke.
See the parts table below.</P><A name=ss5-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&pubid=293&evc=sm#ss5-1580377">
<H5>Parts Information</A></H5>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
Part Number</P></TH>
Description</P></TH>
Usage</P></TH></TR>
<TR>
<TD vAlign=center align=middle>
12477702</P></TD>
Yoke Asm., Prop Shf Slip (with u-joint) , Nickel Plated</P></TD>
4WD/AWD 1500Series Ext Cab Short Box Pickups (New Style and Old
Style)</P></TD></TR>
<TR>
12477704</P></TD>
4WD/AWD 2500Series Ext Cab Short Box Pickups (New
<TR>
12479383</P></TD>
Yoke Asm., Prop Shf Slip (without u-joint) , Nickel Plated</P>
Must Be Ordered With U-Joint Kit P/N 12479126 </P></TD>
4WD/AWD 1500Series Silverado, Sierra Regular Cab Pickups (New
Style)</P>
4WD/AWD 1500Series Suburban, Avalanche, Yukon XL, Escalade EXT,
Escalade ESV with AWD (New Style) </P>
K1500Series Regular Cab Pickup, Tahoe, Suburban, Escalade (Old
<TR>
12479384</P></TD>
Yoke Asm., Prop Shf Slip, (without u-joint) , Nickel Plated
</P>
4WD/AWD 1500Series Tahoe, Yukon, Escalade w/ 4WD or AWD (New
<TR>
12479385</P></TD>
</P>
Must Be Ordered With U-Joint Kit P/N 12471510 </P></TD>
4WD/AWD 2500HD/3500 Series Silverado and Sierra Regular Cab, Long
Bed Pickups with 6.0L (RPO LQ4) Engine (New Style)</P></TD></TR>
<TR>
89058876</P></TD>
4WD/AWD 2500HDSeries Silverado and Sierra Crew Cab, Short Bed
Pickups with 5-Speed Allison Transmission (RPO M74) (New Style)</P>
4WD 2500HD/3500Series Silverado and Sierra Extended Cab Long Bed
4WD 2500HD/3500Series Silverado and Sierra Regular Cab, Long Bed
Pickups with 5-Speed Allison Transmission (RPO M74 build date before
2/2004) (New Style)</P>
4WD/AWD 2500HDSeries Silverado and Sierra Extended Cab, Short Bed
2/2004) (New Style)</P></TD></TR>
<TR>
89058878</P></TD>
4WD/AWD 2500HD/3500Series Silverado and Sierra Extended Cab
4WD 2500HDSeries Silverado and Sierra Crew Cab, Short Bed Pickups
<TR>
89058880</P></TD>
</P></TD>
4WD/AWD 2500HD/3500Series Silverado and Sierra Regular Cab, Long
Bed Pickups with 5-Speed Allison Transmission (RPO M74 build date after
2/2004) or 6-Speed Manual Transmission (RPO ML6) (New Style)</P>
4WD 2500HDSeries Silverado and Sierra Extended Cab, Short Bed
2/2004) or 6-Speed Manual Transmission (RPO ML6) (New Style)</P></TD></TR>
<TR>
12479126</P></TD>
U Joint Kit</P></TD>
4WD/AWD 1500 Series Silverado, Sierra Regular Cab Pickups (New
Style)</P>
4WD 1500 Series Suburban, Avalanche, Yukon XL) (Escalade EXT, Escalade
ESV with AWD (New Style)</P>
4WD 1500 Regular Cab Pickup, Tahoe, Suburban, Escalade (Old Style)</P>
Tahoe, Yukon, Escalade w/ 4WD or AWD (New Style)</P></TD></TR>
<TR>
12471510</P></TD>
<TR>
88964470</P></TD>
Yoke Asm., Prop Sft Slip (without U joint) Nickel Plated</P>
Must be ordered with U joint kit P/N88964507</P></TD>
HUMMER H2</P></TD></TR>
<TR>
88964507</P></TD>
U-Joint</P></TD>
HUMMER H2</P></TD></TR></TBODY></TABLE>
Parts are currently available from GMSPO.</P><A name=ss6-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&pubid=293&evc=sm#ss6-1580377">
<H5>Warranty Information</A></H5>
For vehicles repaired under warranty, use:</P>
<TBODY>
<TR>
Labor Operation</P></TH>
Labor Time</P></TH></TR>
<TR>
F0060</P></TD>
Slip Joint, Propeller Shaft - Replace</P></TD>
0.6hr</P></TD></TR></TBODY></TABLE>
</P>
<TABLE width="100%">
<TBODY>
<TR>
<TD align=left width=778><FONT size=1>GM bulletins are intended for use by
professional technicians, NOT a "do-it-yourselfer". They are written
to inform these technicians of conditions that may occur on some vehicles,
or to provide information that could assist in the proper service of a
vehicle. Properly trained technicians have the equipment, tools,
safety instructions, and know-how to do a job properly and safely.
If a condition is described, DO NOT assume that the bulletin applies to
your vehicle, or that your vehicle will have that condition. See
your GM dealer for information on whether your vehicle may benefit from
the information.
</FONT></TD>
<TD align=middle width=42></TD>
<TD align=middle width=167><FONT size=2>WE SUPPORT VOLUNTARY TECHNICIAN
CERTIFICATION
</FONT></TD></TR></TBODY></TABLE>
<P align=center>© Copyright General Motors Corporation. All Rights
Reserved.
</P>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<TD align=right width="25%"></TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Klaus's Avatar
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
<HR>
</FORM>
Style)</P>
Style)</P>
Cab (New Style)</P>
Shaft ONLY</P>
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&amp;pubid=293&amp;evc= sm#ss1-1580377">
name=ss2-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&amp;pubid=293&amp;evc= sm#ss2-1580377">
<H5>Cause</A></H5>
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&amp;pubid=293&amp;evc= sm#ss3-1580377">
include:</P>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
<DIV align=left>
<TABLE border=0>
<TBODY>
<TR>
name=ss4-1580377><A
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&amp;pubid=293&amp;evc= sm#ss4-1580377">
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&amp;pubid=293&amp;evc= sm#ss5-1580377">
<TBODY>
<TR>
Usage</P></TH></TR>
<TR>
12477702</P></TD>
<TR>
12477704</P></TD>
<TR>
12479383</P></TD>
Style)</P>
<TR>
12479384</P></TD>
</P>
<TR>
12479385</P></TD>
</P>
<TR>
89058876</P></TD>
<TR>
89058878</P></TD>
<TR>
89058880</P></TD>
</P></TD>
<TR>
12479126</P></TD>
Style)</P>
<TR>
12471510</P></TD>
<TR>
88964470</P></TD>
<TR>
88964507</P></TD>
U-Joint</P></TD>
href="http://204.89.220.10:9001/servlets/BlobShtml?ShtmlFile=1580377&amp;pubid=293&amp;evc= sm#ss6-1580377">
<TBODY>
<TR>
<TR>
F0060</P></TD>
</P>
<TBODY>
<TR>
the information.
</FONT></TD>
CERTIFICATION
Reserved.
</P>
<HR>
<TBODY>
<TR>
2003 HUMMER
H2
</TD>
