Old 07-22-2003, 11:44 PM
TroysH2 TroysH2 is offline
TroysH2 is off the scale
I am curious to how many H-2 owner have disscovered that the passenge side wiper arm does not fold completely upward without rubbing against the painted surfaces. It would seem like an easy fix by removing and moving the wiper arm over one or two teeth like on most vechicles. However the H-2 has a pin or guide that makes this impossible. Any suggestion. I did take note at the dealership and most of the H-2's on the lot had the same problem(on the passenger side) thanks again, troy
Old 07-23-2003, 12:19 AM
HappyJack HappyJack is offline
HappyJack is off the scale
Mine does not rub if I rotate it just a little as I bring it up.
This has been talked about before, just do a search and you will find out more info.
Cheers
[ formerly known as wannabe and wannabeinit ]
Cheers
Old 07-23-2003, 05:49 AM
MAC MAC is offline
MAC is off the scale
This is true, but to me that is not a problem, that is just the way it is. Only matters when I wash the window, the solution is to lift the wiper arm a little, take 1/2 second.
Old 07-23-2003, 04:45 PM
BIGT BIGT is offline
BIGT is off the scale
Mac is right. All H2's are like this. Also, don't ever close your hood with the wipers up! This will damage to the hood.
Tony.
Old 07-23-2003, 05:02 PM
Hummer Man is off the scale
Take a 1/2" square rubber cusion and mount it to the wiper arm at the point of contact. This will eliminate paint wear. Theses cusion are roubly 3/32" thick and can be purchased at radio shack and some of the Big BOX DIS stores (LOWES / HOME DEPOT).
Best Regards!
