Old 07-09-2005, 01:02 AM
Dug Dug is offline
Dug is off the scale
Does anyone know the front hitch rating. And is there any kind of extended mirrors out there for the H2 for towing a camper.?? - Doug
Dug Dug is offline
Old 07-09-2005, 02:15 AM
Yetti Yetti is offline
why do you need wider mirrors? are towing a house trailer? the small trailer I have is 101 inch wide and I can see around it pretty easy.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 07-09-2005, 02:17 AM
I would think the hitch should be simular to the rear, given that you can put a 9000lb winch in as rated by the factory.
Yetti
www.wegotmud.com
www.glfwda.org
Old 07-09-2005, 08:57 AM
Dug Dug is offline
[quote]Originally posted by Yetti:
why do you need wider mirrors? are towing a house trailer? the small trailer I have is 101 inch wide and I can see around it pretty easy.[/QUOTe)
I'm towing a 34' camper 1000 miles. I have only towed it once before local and i couldnt see for beans. THe mirrors are 96" wide to the far edges on the H2 and the camper is 100" wide. I was wondering if anyone made any specifically to fit over the H2 mirrors. Thanks , DOug
Old 07-09-2005, 09:02 AM
Dug Dug is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Yetti:
why do you need wider mirrors? are towing a house trailer? the small trailer I have is 101 inch wide and I can see around it pretty easy. </div></BLOCKQUOTE>
I was curious as far as tongue weight. I am sliding in a platform that is 44" x 96" to put two small minibikes and a honda generator. I hope its rated for at least 500lbs. The owners manual say nothing about the front hitch except dont tow a trailer with it. Thanks Doug
Old 07-09-2005, 10:35 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">. The owners manual say nothing about the front hitch except dont tow a trailer with it. </div></BLOCKQUOTE>
Don't you mean "push" a trailer with it?
seriously the hitch should hold that kind of weight, just don't block the grill and cause the truck to over heat.
I was wondering why you are going out so wide? 44" is pretty far in front and will create alot of leverage down on the hitch.
Yetti
www.wegotmud.com
www.glfwda.org
Old 07-09-2005, 07:19 PM
Dug Dug is offline
yes, i will be careful not to block the radiator to much , i am a little nervous about that. The only reason i am using the rack that is 44" deep is because i already have it. It goes on the back of my portable toilet rental truck and holds two porta pottys for delivery. My luck i'll probably break something . Thanks, doug
Old 07-10-2005, 01:27 AM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dug3x3:
Does anyone know the front hitch rating. And is there any kind of extended mirrors out there for the H2 for towing a camper.?? - Doug </div></BLOCKQUOTE>Most Auto Parts stores offer extended mirrors that can be attached to the factory mirrors temporarily for towing wide loads. I saw a set @ Advance today.
Old 07-10-2005, 07:09 PM
Dug Dug is offline
Thanks i'll check it out. Maybe there is a generic type that will slide over the h2 mirrors. ..
