Old 05-26-2005, 06:01 PM
Bill Kervaski Bill Kervaski is offline
Bill Kervaski is off the scale
Maybe I missed it but you can't do XM and the iCruze at the same time?
- Bill
Old 05-27-2005, 02:54 AM
tower's Avatar
tower tower is offline
Do any of these devices beside the I-Cruz display actual data (title, artist, etc.)? If so, can they display it through the factory head unit, or do they require an outboard display like th I-cruz?
Old 05-27-2005, 11:43 AM
md_sailor's Avatar
md_sailor is off the scale
I dont believe there is any display it should look like the CD Changer display, Instead of discs you will have your pre-programed play lists.
Old 05-18-2006, 02:45 PM
mwrbunny mwrbunny is offline
mwrbunny is on a distinguished road
Default Re: New iPod Adapter for GM Factory Audio Systems
If you mount the ipod adapter unit behind the glove compartment, can you get to it later without having to remove center console & dash again? (there are some DIP switches on the USA Spec unit that you might want to change later..)
(so I guess the real question is, can the interior of glove compartment be pulled out fairly easily?)
Old 05-18-2006, 02:49 PM
kodiakz kodiakz is offline
kodiakz is off the scale
Very easily!
Old 05-18-2006, 06:19 PM
I can see that now.......DUH!! (glove compartment door drops right down after you dis-engage that "doo-hickey" on the right side.)
As respects the ipod unit, I've decided on the USA Spec unit after much, much consideration......the primary reason is because I want to have the full control of the IPOD unit so that I can pull down music "by artist" instead of playlists only.
The advertising for the USA Spec unit says that it will display text on the NAV unit if you run it through the XM channel..............HOWEVER, I have heard from an installer that it doesn't work.......ever!
No doubt, it would be way-cool if it worked. Anybody been able to get text up with this unit on their NAV w/XM????? (I have a 2006 H2 by the way)
