Old 10-17-2005, 02:08 AM
wannabeH3's Avatar
so after my water fording experience, i checked my rear diff for sludge, and its ok, however isnt oil sposed to come out of the drain hole? the level seemed to be a 1/4 to a 1/2 inch below the hole... also is it just straight 90 weight? tranny fluid looked good too, is there anything on the front that needs to be checked? and where is it?
2) wheel bearings, how bout these? do they need to be repacked after going in water? how do you do it on this guy?
(with insurance)
wannabeH3's Avatar
(with insurance)
Old 10-17-2005, 02:23 PM
Hummertech is off the scale
Wheel bearings do not need to be repacked. These are lubricated by your diff fluid in rear axle. Fluid level should be to bottom of plug. If it's just slightly below, that's fine too, just add some. No it's not straight 90 weight. It's synthetic.
Old 10-17-2005, 11:04 PM
wannabeH3's Avatar
thanks for the info!
(with insurance)
Old 10-17-2005, 11:14 PM
Desert Dan's Avatar
What did the diff oil look like?
If it looked greenish and foamy you should drain and flush it?
How deep was the "Fording" depth
no pun intended
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-18-2005, 05:37 AM
wannabeH3's Avatar
naw it was black, not milkshakeish.. the depth, well im not sure.. take a guess:
(with insurance)
