12-01-2003, 06:38 PM
I know the last time I spoke with S&J Fox, They were looking for a good tape for their Magnetic Panels.
Give this tape a try.
It is made by 3M and comes in several different colors.
Model# 3m764.
We use it a work, and it seems to work fairly well, and it's wide enough to hold almost anything down.
Good Luck
Ric
www.meatspin.com
Model# 3m764.
Good Luck
Ric
www.meatspin.com
12-01-2003, 10:35 PM
I assume that it acts like masking tape - easy to remove without residue or paint damage.
Brian
03 Pewter H2 Lux, Airaid filter/MIT, Nology Wires, Corsa Touring
Brian
03 Pewter H2 Lux, Sunroof, Airaid filter/MIT, Nology Wires, Corsa Touring
12-02-2003, 01:15 AM
I used to buy a bit of tape from 3M and they make several good adhesive tapes that would work for the shields. Here is a 3M Page that lists their 890X series that seems as if it would do a good job in hotter climates. The spec does not talk about temps under 70F but I would think that a silicone adhesive would handle just about anything to under freezing. The spec is in this PDF. McMaster-Carr is a great place to find tapes and also get FREE SAMPLES if you ask nice.
________________________
Black 2003 H2 - Just like most of yours, just possibly with less crap bolted on.
My job: http://www.HardOCP.com
This place sucks now, bye.
12-02-2003, 02:29 AM
Seth,
FrgMstr is right on when he showed concern about heat sensitivity. You might be better off by going to a higher heat resistnt tape. I'm glad he attached a reference link to 3M, I may order some stuff off the site myself.
Thanks, and good luck tape hunting.
Ric
p.s. if you still wanna give this tape I've got at work a try, I can probably get a roll or two.
[This message was edited by RIC-H2 on 12-01-03 at 08:42 PM.]
www.meatspin.com
