02-12-2006, 11:58 PM
02-13-2006, 12:52 AM
Little busy isn't it? I don't mind the wrap around bumper guard, I'm not fond of the way it comes up and around the hood filler/handles.
Mark
02-13-2006, 01:06 AM
Ditto. Don't like the handles either.
02-13-2006, 01:20 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by OrangeCrush:
Mark </div></BLOCKQUOTE>
I agree with you. Way to busy for me.
2006 H2, Black with bling!!
02-13-2006, 01:32 AM
i like it.
02-13-2006, 01:50 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by yodawagon:
i like it. </div></BLOCKQUOTE>
it's differnt! not bad.
But look at the way it mounts. If you bump anything, I would be more worried about the way it is bolted into your hood. Instead of replacing a brushguard, you may be dealing with a new hood.
02-13-2006, 02:35 AM
alot or almost all of these so called "brushguards" are funny to me, unless u can really ram some ****t with it than wat is the point, i remember when i had the wrangler back in the day there was a company called tompken machine that made some "real" guards my buddy had one on his cherokee and that thing was a brushguard im almost positive u could run right throug a brick wall with it and not need a bodyshop after u were finished
02-13-2006, 04:16 AM
To be so large, I don't think the tubes are large enough. I prefer this one. It even has mounts that go through the grill to the stock bg attachment points. The one listed above doesn't.
02-13-2006, 04:18 AM
02-13-2006, 04:53 AM
The design of the one on ebay has to use the holes for the handles for support, where the one Ken posted is designed to be stronger over the hood without having to use the handle mount locations.
02-13-2006, 04:59 AM
The design of the one on ebay has to use the holes for the handles for support, where the one Ken posted is designed to be stronger over the hood without having to use the handle mount locations. </div></BLOCKQUOTE>The one I have uses new, aluminum handles the BG mounts to, and large fender washers under the hood for strength.
02-13-2006, 05:39 AM
i like the trail duty one better for sure. buts flat black, and 1600.00
02-13-2006, 05:45 AM
i like the trail duty one better for sure. buts flat black, and 1600.00 </div></BLOCKQUOTE>And I can walk on it. Hell, ask for a discount. What's the worst thing that could happen? You get told NO. Big deal.
