Old 03-31-2004, 08:40 PM
TroysH2 TroysH2 is offline
TroysH2 is off the scale
Took H2 in for non-service (see post "OUTPUT SHAFT-Drivers Side-DEALER?")
They mentioned that there is a Recall on the Ignition Switch.
R/R with new switch.
Did not see a previous post on this recall.
Best of Luck,
Troy
Best of Luck,
Troy
Best of Luck,
Troy
Old 03-31-2004, 11:25 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Funny that you mentioned this.
I just took mine in for the trigger switch not activating the enter/exit position when I take the key out. I had to take it in and out several times before it would work.
I will be picking up my vehicle tomorrow, and will let you know if they replaced it as a recall item or just took care of the switch.
Thanks for the heads up!
Ric-H2
www.meatspin.com
