05-18-2003, 09:51 PM
Finally got the SMA Brushguard installed. I love it.
-Jim March
Arlington TX
2003 Red H2
Beauty is in the eye of the Beer Holder
-Jim March
Arlington TX
2003 Red H2
05-18-2003, 09:52 PM
Pic 2
-Jim March
Arlington TX
2003 Red H2
3
-Jim March
Arlington TX
2003 Red H2
4
-Jim March
Arlington TX
2003 Red H2
05-18-2003, 09:53 PM
5
-Jim March
Arlington TX
2003 Red H2
6
-Jim March
Arlington TX
2003 Red H2
05-18-2003, 09:54 PM
Last One
-Jim March
Arlington TX
2003 Red H2
05-18-2003, 10:29 PM
Beautiful truck D. Are those pins that hold the bar in the upright position? My Manik bar has funky wing nuts and some sort of bike quick release bolt. I have thought about changing to something else. So question two is: Does it vibrate and make any noise?
Goodness, we do not have many concrete neighborhood streets, just high speed roads. And your street is grooved, do much drag racing there...
Black Lingenfelter Lux
05-18-2003, 10:42 PM
Yep. The "T" pins hold the Brushguard upright. It doesn't vibrate or rattle or anything. But I did notice a considerable increase in wind noise after installing it.
However, it doesn't bother me at all. But those that are agitated by wind noise should certainly avoid the SMA Guard.
-Jim March
Arlington TX
2003 Red H2
05-18-2003, 11:15 PM
Jim,
You must be holding the beer just right. Nice set up and very nice home. What's the sticker in the back window? Looks like either NRA or USMC.
05-18-2003, 11:42 PM
Thanks buddy.
It's a USMC sticker. I was in from 93-97.
The weekend after memorial day weekend I should be getting my rims powder coated flat black. Should make for some nice pictures.
-Jim March
Arlington TX
2003 Red H2
05-19-2003, 02:31 AM
Jim,
Good to see it - I think it looks awsome!!
I want one.
Now, did you say you installed it or your dealer? If you did how hard/easy was it?
John
JSA_3 (west texas white)
\'02 HMCO
05-19-2003, 09:45 AM
I installed it myself. It wasn't very hard, but there was a bit of drilling and cutting involved, which made me a bit uncomfortable.
But everything turned out ok.
-Jim March
Arlington TX
2003 Red H2
05-19-2003, 12:38 PM
Well it looks great!
John
\'02 HMCO
06-04-2003, 10:31 PM
Hey Detonate, could you give me a bit of detail on what you had to drill, cut, bolt, etc. What tools did you need? How long did it take? I'm considering this grill guard and would appreciate you elaborating. Looks awesome on your rig, I think it is the best grill guard on the market for the H2. Thanks in advance.
H2 '04 Black
06-05-2003, 01:03 PM
Most of the tools were pretty standard stuff. A drill, some sockets, and a screw driver. The only thing I "had" to buy was a Dremel tool.
Basically the install involved taking off the plastic piece that holds the Daytime running lamps. That piece is basically hollow, except for another plastic piece inside...
This piece basically looks like |-|-|-|-|-| and is used to keep the shape of the other piece...
You have to take that out and cut out the outline for the guard brackets using a dremel. Then the outer shell you have to cut 2 holes using a hole saw to fit the mounts.
To go back to stock, I'd have to replace the plastic part of my bumper and that's it.
Oh, and there is are 4 holes I think that you have to redrill to make bigger for some beefier hardware...
If I saved the instructions I can scan it and upload it...
It really wasn't that difficult and I did it by myself in a few hours...
-Jim March
Arlington TX
2003 Red H2
06-05-2003, 11:39 PM
Thanks for this detail, Jim, that seems very doable even for me. As long as there's no metal to cut, drill, etc., I can handle it. I'm sure the instructions will come with it so don't worry about scanning, but thanks!
H2 '04 Black
06-06-2003, 12:05 AM
Trust me. If I can do it. Anyone can.
You should have seen some of my failures from Metal and Woodshop. This is why I'm in computers and not construction.
-Jim March
Arlington TX
2003 Red H2
06-06-2003, 02:16 PM
I would like to find a modified factory wrap-around that hinged like that! Would make scraping the bugs off much a easier task!
Check out the OkC Chapter Page!
