12-04-2003, 09:13 PM
Ok, Im right in the middle of my XM radio installation and im down to hooking up the 2 yellow power leads (1 from the tuner and one from the adapter)?  Call me dumb but where can I hook those wires up so they get constant juice. Any suggestions would be appreciated. I dont want to burn down my Hummer.
12-04-2003, 09:17 PM
Don't know anything about electrical matters but in planning my system I'm planning on tapping into Cig Lighter leads. Don't know if it is safe or even possible though I was looking for suggestions.
03 Black Adventure with all Lux Options,Brush Guard Lights, and Sylvania Silverstars. Go Vols!!!
12-04-2003, 09:19 PM
I hooked mine up to the cig lighter that I do not use. The one behind the shifter. It works fine and I have two phone chargers plugged into the other two.
Craig
04 Pewter H2- Lux,nav, air suspension
Craig
12-04-2003, 09:34 PM
Thanks guys. Are those hot all of the time?
12-04-2003, 09:50 PM
Ok, im using the lighter hot (red) line. can I use the lighter hot for the ground or do I have to find some metal. As you can see Im a wuss when it comes to electricity.
12-04-2003, 10:22 PM
Dude,
All you had to do was PM me a number to reach you at and I would have explained everything in detail.
Did you get my antenna message??
12-04-2003, 10:30 PM
Patriot,
I did get the antenna message. I attached the yellow hot leads to the orange on the cig liter. Can I hook that ground to the black ground on the cig liter?.
12-04-2003, 10:32 PM
Patriot,,,
Im trying to do the PM but I keep screwing it up
12-04-2003, 10:37 PM
I used the cig lighter ground and power (both).
I get a small amount of hiss (alternator) that you can hear only during dead air or in between stations.
If you do put it there and have a prablem, you can always run a seperate ground wire to a more preferred location.
12-05-2003, 02:02 AM
Thanks all,
I got the XM going and it sounds great. I cant seem to get the display to work though. I ll be calling soundgate in the morning.
12-29-2003, 09:37 PM
Where is a good place to ground the PIOGM1 using Cig. Lighter for 12V lead
12-29-2003, 10:01 PM
Touch,
I used both the "positive/juice" and "negative/ground" cig lighter wires.
12-30-2003, 01:22 AM
Thanks for the info. I've got my I-pod in hand. PIOGM1V2 on its way and I am ready to install this thing and try it for myself. Any hints or suggestions. Looking for info. you wish you would've known before starting the install. Thanks,
