Old 02-10-2006, 05:28 PM
So, many of you have talked to Amanda in my office before. She asked me why I never post anything here about work and basically accused me of cheating you guys out of valuable information. So she has found a series of articles and information for you guys that she'll be posting. Let me know if you want us to knock it off. Seriously.
PAY OPTION LOANS:
This loan program is an adjustable rate mortgage with added flexibility of making one of several possible payments on your mortgage every month, in order to better manage your monthly cash flow.
It's low introductory start rate allows you to make very low initial mortgage payments and low qualifying rates enable you to qualify for more home.
The minimum payment option can help keep your monthly payments affordable. If the minimum monthly payment is not sufficient to pay the monthly interest due, you can always avoid deferred interest by choosing the interest-only payment option.
With the Option ARM, you generally have at least two fully amortized payment choices, leading to a quicker loan payoff. If you prefer to pay off your loan on schedule, you can make the fully amortized payment based on a 30-year loan, or you can choose the 15-year payment option for the fastest equity build-up.
In most cases, you can also make additional principal payments which reduce the amount you need to pay in later months.
Option ARM loan programs are right for you if you'd like to own your property only for a short time, and prefer affordability and flexibility in your monthly payment. However, if you select the minimum payment option in the early years, you should be prepared for possible sudden increases in your monthly payments thereafter.
Option ARM loans have four major types of payment options:
Minimum Payment
With the minimum payment option, your monthly payment is set for 12 months at your initial interest rate. After that, the payment changes annually, and a payment cap limits how much it can increase or decrease each year.
If you make the minimum payment after the end of your initial interest rate period, which holds only for the first month, it may not be enough to pay all of the interest charged on your loan for the previous month and the unpaid interest will be added to the principal balance you owe (will be deferred).
Interest-Only Payment
With the interest-only payment option, you can avoid deferred interest, when the minimum payment is not enough to pay the monthly interest due. The interest-only payment option, however, is not available if the interest-only payment would be less than the minimum payment. Please note, that this payment option does not result in your principal reduction.
The interest-only payment may change every month based on changes in the ARM index used to determine your fully indexed rate.
Fully Amortizing 30-Year Payment
With fully amortizing payments, you pay both principal and interest and keep your loan on schedule. Your payment is calculated each month based on the prior month's fully indexed rate, loan balance and remaining loan term.
Fully Amortizing 15-Year Payment
If you prefer to put your loan on an accelerated schedule and can afford higher monthly payments, the 15-year payment option allows you to repay your loan twice as faster and save more than half the total interest costs of a 30-year loan.
Please note, that this payment option is offered only on the 30-year (or 40-year) term. It will cease to be an option when the loan has been paid to its 16th year.
These options should be clearly marked on your loan statement, so it is very easy to figure out how much you should pay each month. Just enter the correct amount in the payment coupon section of your statement.
Option ARM loan programs are becoming more and more popular today, and there are many variations of this innovative home financing product on the market: Pay Option ARM, Pick-A-Payment Loan, 1 Month Option ARM, CashFlow Option Loan, LIBOR (or 12-MAT) Pay Option Loan, etc. If you are thinking about applying for an option ARM, it is important to shop carefully and investigate several loan products, to find the one best for you.
Option ARM loan programs may vary in the initial rate, negative amortization and lifetime caps, ARM index, or optional features, however, when comparing one option ARM with another, pay close attention to the margin and the fully indexed rate. Keep in mind that the initial interest rate holds only for the 1st month.
What features to compare with different Option ARM loans?
Loan Term
Option ARM loans are available for 30 or 15 years. *
Initial Interest Rate
Your Minimum Payment Rate or 'Start Rate'. It may vary from 1.25% up to 3.95% and depends on your Loan-to-Value Ratio (LTV).
Initial Interest Rate Period (Introductory Period)
With 1-month option ARMs, the initial interest rate holds only for the first month, thereafter the interest rate may change monthly.
During the introductory period: After the introductory period:
Monthly Payment = Minimum Payment
Interest Rate = Start Rate
or Interest-Only Payment
or Fully Amortizing 30-Year
or Fully Amortizing 15-Year
Interest Rate = Fully Indexed Rate
Periodic adjustments after the introductory period:
Event Loan Feature Change Frequency Cap
Monthly Interest Rate Adjustment Fully Indexed Rate Monthly Lifetime Cap
Annual Minimum Payment Change Minimum Payment Annually Payment Change Cap
Loan Recast Minimum Payment Every 5th Year None
Other adjustments:
Loan Recast (negative amortization limit is reached) Minimum Payment Irregularly None
Fully Indexed Rate (FIR)
The sum of the margin and the most recent index figure available prior to a scheduled interest rate change date. Subject to the interest rate caps.
Interest Rate Adjustment Period
The time between interest rate adjustment dates.
With option ARMs, the adjustment period is usually set to 1 month: the fully indexed rate may not change more than once every month based on the movement of the index.
Maximum Rate
See: Lifetime Cap.
Lifetime Cap
A lifetime cap limits the interest rate increase over the life of the loan. It protects you financially and usually is expressed as maximum rate. Lifetime caps may vary from 9%-10% up to 19%.
Lifetime Floor
See: Margin.
Minimum Payment
Initially (for the first 12 months), the minimum payment is calculated using the start rate, the amount you borrow and the loan term. Thereafter, it is recalculated annually.
Example:
Loan Amount: $200,000.00
Initial Rate: 1.25%
Index: 3.751 (MTA as of January 2006)
Margin: 2.75%
Payment Cap: 7.5%
Fully Indexed Rate: 6.501% ( = index + margin )
Minimum Payment Changes:
Year 1 $666.50 = Base of Minimum Payment
Year 2 $716.49 = $666.50 + 7.50%
Year 3 $770.22 = $716.49 + 7.50%
Year 4 $827.99 = $770.22 + 7.50%
Year 5 $890.09 = $827.99 + 7.50%
Minimum Payment Adjustment Period
The minimum payment adjustment period is usually set to 12 months, unless negative amortization limit is reached.
Minimum Payment Change Cap
A limit on how much the minimum monthly payment can change at each adjustment. With most option ARMs, your payment cap will be 7.5% of minimum payment amount in first five years. It means that on any Payment Change Date, the minimum payment cannot increase or decrease by more than 7.50% (unless the loan is
recast or the negative amortization limit is reached).
Negative Amortization Cap (Also known as: Balance Cap, Negative Amortization Limit, Negative Amortization Ceiling)
It limits the loss of equity in your home when low monthly payments do not cover fully the interest rate charges agreed upon in the mortgage contract and is usually set to 110% - 125% of your original principal balance. When the negative amortization limit is reached, the minimum payment increases immediately: the payment required to fully amortize the loan over the remaining term becomes the new minimum payment, and the payment cap does not apply.
Payment Recast Period
Recasting (or re-calculating your loan) is another way of limiting negative amortization and keeping your loan on the original schedule. Option ARM loans are recast every five years (or sooner, if the negative amortization limit is reached). This re-calculation is based on the outstanding principal balance, the remaining term and the fully indexed rate. When the loan is recast, the payment required to fully amortize the loan over the remaining term becomes the new minimum payment, and the payment cap does not apply (the payment cup, however, will go back into effect immediately after the recast, and will hold until the next time your loan is recast).
Index Options
Your interest rate is usually based on one of the following indexes:
Monthly Treasury Average (MTA)
Cost of Savings Index (COSI)
London InterBank Offered Rate (LIBOR)
11th District Cost Of Funds Index (COFI)
These indexes change once a month.
Click on index title for explanations. Click here for current and historical values.
Historical performance of the four most popular option ARM indexes over the last 14 years.
Margin
The number of percentage points (for example, 2.75) the lender adds to the index rate to calculate the ARM interest rate at each adjustment. The margin is set in the mortgage contract, remains fixed for the term of the loan and is not impacted by the financial markets and movement of interest rates.
Caps
Option ARMs don't have First Interest Change Cap or Periodic Interest Change Cap.
They have:
Lifetime Cap (or Maximum Rate)
Lifetime Floor (or Margin)
Payment Cap (or Minimum Payment Change Cap)
Balance Cap (or Negative Amortization Limit)
Documentation Types
Full doc, Limited doc, Low doc, Stated Income, No Income\No Asset (NINA), Stated Income\Stated Assets (SISA). Read more about Loan Documentation Requirements. Click here for a list of documents most lenders will require in order to process your mortgage application.
Loan Program Variations / Options / Special Features
Initial Fixed Rate Period
An option ARM loan may have an initial fixed rate / fixed minimum payment period of 3 or 5 years between the time the loan is originated and the first interest rate change date. After the initial period the loan converts to monthly adjustable Option ARM (the interest rate adjusts every month and you will have payment options).
40-Year Term
Some option ARM loans, for a fee (or for an increase in your rate), contain a provision permitting you to increase the term of the loan from 30 to 40 years.
Bi-Weekly Payments
Some lenders offer optional bi-weekly payment plans with option ARMs. With bi-weekly mortgage plan you pay half of the monthly mortgage payment every 2 weeks. It allows you to repay a loan much faster. For example, a 30 year loan can be paid off within 18 to 19 years.
Conversion Option
The interest rate or points may be somewhat higher for a convertible option ARM, and it also may require a small fee at the time of conversion.
Option ARM Calculator { Option ARM Loan Amortization }
Loan Amount: $
Initial Rate: %
4.572 (1-Month LIBOR as of January)
3.296 (COFI as of December)
3.240 (COSI as of December)
Other:
Margin: %
Minimum Payment: $666.50 ( Deferred Interest: $417.00 )
Interest Only Payment: $1,083.50
Fully Amortizing 30-Year Payment: $1,264.27
Fully Amortizing 15-Year Payment: $1,742.32
Fully Amortizing 40-Year Payment: $1,171.06
-Amanda
Old 02-10-2006, 07:28 PM
Adam, change your password! Someone named Amanda hijacked your handle and posted useful info.
Old 02-10-2006, 07:44 PM
I gave it to her.
Old 02-10-2006, 10:09 PM
Boss Hoss's Avatar
Boss Hoss is off the scale
Countrywide 3yr hard pp pay option=3pts on back
Old 02-11-2006, 04:26 AM
Admanda
Sorry, no good info allowed, only pads.
Old 02-11-2006, 05:46 AM
The only thing worse than reading this thread, is reading Adam's signature.
Old 02-11-2006, 05:47 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Adam in CO:
........Any and all violations will be persecuted to the full extent of the core group. </div></BLOCKQUOTE>
LMAO!
Now THAT is funny.
Old 02-14-2006, 02:39 PM
Thank you.
