Old 07-26-2005, 01:15 AM
OldHiker OldHiker is offline
Has anyone had the steering basically lock up when you try to turn the wheel while not moving. As soon as I release the brake, the wheel frees up. I've had the steering box replaced without change.
Old 07-26-2005, 02:59 AM
techray techray is offline
techray is off the scale
well i'm sure someone may have already told you but just incase. this is most likly a normal thing. due to the hydro-boost brake system. this system includes the p/s system. there for has a direct effect to each other. By dry steering (which is not good on anything on the rig!) and the brake on the pressure is too great for the p/s release valve. Thus opening the valve making the assist from the power steering pump low if at all. As for the sudden un-binding when you release the brakes, that the rotors and steering system releaving all the force you just applied now that the wheels can rotate. Hope this helps
Old 07-26-2005, 03:45 AM
techray, are you another HUMMER tech? Man, if you are, WELCOME! Great to have you aboard.
If you're not, GFY.
Welcome to the forum.
Old 07-26-2005, 01:10 PM
Hummertech is off the scale
That is normal to an extent, but it is much worse if your front tire pressure is low. I'm willing to bet you're low on air pressure, because the steering is usually very liveable when you're air pressure is correct.
Old 07-26-2005, 04:23 PM
You guys are spot on. It is really noticable when I have deflated to around 20-25 lbs while off-roading. What else can I do?
Old 07-26-2005, 07:36 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by techray:
well i'm sure someone may have already told you but just incase. this is most likly a normal thing. due to the hydro-boost brake system. this system includes the p/s system. there for has a direct effect to each other. By dry steering (which is not good on anything on the rig!) and the brake on the pressure is too great for the p/s release valve. Thus opening the valve making the assist from the power steering pump low if at all. As for the sudden un-binding when you release the brakes, that the rotors and steering system releaving all the force you just applied now that the wheels can rotate. Hope this helps </div></BLOCKQUOTE>
AAAHHHHH!!! Everyone, techray(So imaginative) is my tech and has been so for about 2 years. He is to be extended diplomatic immunity. He just fixed the clunking and grinding noise in the front end of my H2. And he's lucky he did or I was going to have to beat him with my shoe.
He knows his fashizzle.
Old 07-27-2005, 12:48 AM
He knows his fashizzle. </div></BLOCKQUOTE>
Techray! YAY! You made it!
Diplomatic immunity times 2! He fixed my rig many times. oops, I mean frequently. Oops, I mean on occasion. I meant once, and only once.
Old 07-27-2005, 02:10 PM
It's mormal at low air (I hope )
Techray is troll </div></BLOCKQUOTE>
What's "mormal"? were you thinking of mammaries when you typed that?
Old 07-28-2005, 12:37 AM
A troll uh ! well be it so there will be no Alec W's crossing by bridge
Old 07-28-2005, 04:29 AM
A troll uh ! well be it so there will be no Alec W's crossing by bridge </div></BLOCKQUOTE>He can only make English crossings... NOT American.
Old 07-28-2005, 05:02 AM
txsteal77 txsteal77 is offline
txsteal77 is off the scale
hey ltes not mkae fun of ecah ohter smoe of us cnat splel taht wlel. paly ncie now.
