Old 09-25-2005, 11:28 AM
Av1ator Av1ator is offline
Av1ator is off the scale
THe only thing my H3 did not have that I wanted is a hitch. I ordered a Hidden Hitch which will be here this week. I plan to install it myself, they say I can do it in 30 mins. My question is whats the best/right way to tap into the lights? IS there a hidden connector to add a harness to?
Old 09-26-2005, 06:21 PM
UPS brought my hitch this afternoon..it took only 30 mins to install...now I just have to figure out how to run the lighting wires!
Old 09-26-2005, 10:19 PM
There might be a bundle of wires taped up somewhere at the rear of the vehicle that contains the following wires in the bundle (may not have all these wires, but at least the park/turn/backup)
Yellow – left rear stop/turn supply
White – trailer ground
Dark blue – trailer aux supply
Dark green – right rear stop/turn supply
Red – Battery positive
Brown – trailer park lamps supply
Light green – backup lamp supply voltage
Old 09-27-2005, 12:18 AM
Thanks fo the Input..Hope to have time sometime this week to investigate..will report how I come out!
Old 10-03-2005, 11:15 PM
FormerJeeper FormerJeeper is offline
FormerJeeper is off the scale
Who's hidden hitch did you get and where did you get it?
Cheers
-C
Old 10-04-2005, 01:02 PM
I'm planning to put one too....
Old 10-05-2005, 10:25 AM
I bought the hitch from
http://www.etrailer.com/
They had it in stock..FAST shipping and good price!
I hooked up the lights too! All the wires you need are taped to the main bundle near where the tag light pig tail comes off.
I post some pics and other info here:
http://elcova.com/groupee/forums/a/t...5/m/1921063831
Old 10-05-2005, 12:09 PM
thanks Av1ator, do u have a pic how it looks from the rear...
Old 10-05-2005, 08:37 PM
HEEERE Ya go!
Old 10-05-2005, 08:49 PM
fourfourto's Avatar
looks like you dont need a stepdown factory one is higher might nead stepdown
Old 10-16-2005, 02:38 PM
techray techray is offline
techray is off the scale
if you would like to have all 6 pins you need to run a few wires from the front right behind the battery box in the connector. the 12 volt battery and back up light voltage is there. just incase.
Old 04-04-2006, 12:49 PM
H3less's Avatar
H3less H3less is offline
H3less is off the scale
What's the factory one look like? Any photo's out there? Is it incorperated into the rear bumper? Hope so!
Old 04-04-2006, 01:10 PM
fourfourto's Avatar
Posted Apr 4, 10:49 AM
Look in photo section tons of pics.this will get you started
Old 04-04-2006, 01:15 PM
The install turned out clean!
Old 04-04-2006, 02:23 PM
H3less's Avatar
Thanks, much better with the factory hitch. too bad it's not done right on all of them! but the install looks nice on the aftermarket! There are skid plates for hitches so at least it'll slide a little
Old 04-04-2006, 02:37 PM
A lot of dealers order all their H3s for stock with the hitch because of how it integrates with the bumper. If you order it with the hitch, tell them you don't want the trailing accessory kit or whatever it's called. They charge $150 for it but I have seen everything that comes with it at Wal-Mart for about $25 total.
Old 04-04-2006, 07:12 PM
H3less's Avatar
So what is "included" in the accessory kit?
Old 04-04-2006, 08:24 PM
Per Hummer.com
Old 04-05-2006, 12:33 PM
H3less's Avatar
That's it??? I don't think so, put the $ tword under body or brush gaurd. Thanks for the info!
Old 04-13-2006, 03:03 PM
If anyone is looking to get a hitch for their H3 there is a full rear bumper with hitch and including wiring and brackets on Ebay right now.
