Old 12-22-2005, 05:26 PM
coach3rd coach3rd is offline
coach3rd is off the scale
Anyone have or seen this problem with the heater set to 90 and blowing cold. I have had this in the shop for this before and they say the flap for outside is not closing properly but I would like a permanent fix. They take off the dash and close the door?
Old 12-22-2005, 05:46 PM
dochummer's Avatar
Have you tried running the heater with the engine on? j/k Never heard of the problem...sorry, can't help...
'03 H2
Old 12-22-2005, 06:08 PM
I had something similar happen on another
gm product. It was an issue with the vacuum which caused the blower to put out ONLY hot air.
Take your truck to Great Neck RD heading north over the bridge. Go fast. When you get to the top, take your foot off the gas and coast all the way to the light. Your truck will pull vacuum and may fix the problem.
I know it sounds wierd, but it worked for me on the old Tahoe.
Old 12-23-2005, 10:03 AM
intimidator intimidator is offline
intimidator is off the scale
you have a faulty temperature door actuator. take it to the dealer if you have a warranty. and make sure they recalibrate the hvac doors.
Old 12-23-2005, 12:37 PM
kodiakz kodiakz is offline
kodiakz is off the scale
I have the exact same problem. Mine is intermittent, but if I have the heater set to anything less than 90 it only blows cold air. Oh well, the warranty list continues to grow!!!
Old 12-23-2005, 01:58 PM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
With the heater running try pressing the a/c button. This should show the a/c icon with an x through it. Worked for me.
Ed
2008 H3 Alpha - Boulder Gray
