Old 09-03-2003, 09:50 AM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
I have seen several H1's and H2's (off-road run videos) with large US Flags mounted from the rear of the vehicles and would like to do so for parades, special events. (I have an H2)
Can any of you post pics/info on mounting them?
I'm thinking of those with the flag pole holding the flag at near vertical.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Hum2's Avatar
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-03-2003, 10:32 AM
Hum2's Avatar
Thanks Phil!
That's kind of what I was thinking of...Did you make it yourself or can it be purchased cheaply? :-)
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-03-2003, 11:41 AM
Hum2's Avatar
Thanks much Phil...looks great!
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-03-2003, 11:48 AM
ckhagman ckhagman is offline
ckhagman is off the scale
www.leftysautomotive.com
http://www.penta-nut.com
The Most Sirius Off-Road Vehicle
Old 09-03-2003, 11:59 AM
Hum2's Avatar
Thanks Chris!!!
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-03-2003, 12:57 PM
DiscoDancingRover DiscoDancingRover is offline
DiscoDancingRover is off the scale
http://www.leftysautomotive.com/acce...ssoryMisc3.htm
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind"
Old 09-03-2003, 01:12 PM
Steve R Steve R is offline
Steve R is off the scale
because....in the end....the H2 is nothing more then a $55K flag pole
Old 09-03-2003, 01:26 PM
Hum2's Avatar
Funny Steve!
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-05-2003, 10:58 AM
Hum2's Avatar
I have a cheap fix....1" dia copper piping 18" long. Smashed 3 inches on one end in a vice, bent it at 90 degrees. Will drill a couple holes to screw/bolt the flat spot to a 2X4, 8" long, then, bolt the 2X4 to the trailer hitch. Flag pole slides into the copper piping.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 09-05-2003, 03:56 PM
Hum2's Avatar
Hey Joyce:
I just started the idea this AM before work (just bent the pipe). I was thinking about buying a 1" bit to drill a hole that matched the ball mount hole and bolt there, then I thought I might mount it to a 2X4 and bolt the 2X4 to the hitch ball mount.
I will post pics when I get time to play with this. I'm sure there are other possibilities. The Lefty's unit (http://www.leftysautomotive.com/acce...ssoryMisc3.htm) is pretty good as well. (but $40).
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
