Old 12-08-2002, 01:23 AM
Klaus's Avatar
Klaus Klaus is offline
Document ID #
2003 HUMMER HUMMER
Transmitter Programming
Important
All transmitters which are to be recognized by the Passenger Door Module
(PDM) must be programmed in a single programming sequence unless the scan tool Program Individual Key Fobs menu is used. Otherwise, if the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. You may program up to 4*transmitters, using either of the 2 following
procedures:
Method 1 - No Tools Required
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15*seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to four transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
9. Operate the transmitter functions in order to verify correct system operation.
Method 2 - Scan Tool Required
1. Install a scan tool.
2. Turn the ignition ON, with the engine OFF.
3. Use the scan tool in order to access the PDM, Special Function: Program All Key Fobs menu.
4. Follow the directions on the scan tool in order to program the transmitters.
5. Operate the transmitter functions in order to verify correct system operation.
To program just a single transmitter:
3. Use the scan tool in order to access the PDM, Special Function: Program Individual Key Fobs menu.
4. Follow the directions on the scan tool in order to program the transmitter(s).
© Copyright General Motors Corporation. All Rights Reserved.
Document ID #
2003 HUMMER HUMMER
Klaus's Avatar
Document ID #
2003 HUMMER HUMMER
Important
procedures:
Document ID #
2003 HUMMER HUMMER
Old 12-08-2002, 06:09 PM
JCJ JCJ is offline
JCJ is off the scale
Klaus rrrrealy helped me out here!
I was stuck with a non-functioning # 1 keyless entry remote fob.
The local GMC dealer is still waiting for the software upgrade for the scan tool (the handheld car-computer interogator) to do the programming in the Hummer H2.
But thanks to H2 club-forum in general and this technical document post in particular I taught the Hummer to recognize the other remote fob.
At 1st I was worried about the security issue, but you need to use your ignition key and be inside the car to do it, so it was a snitch!
Now the spouse finaly can also make use of the memory feature of chair, mirrors, radio-channels, AC etc. thanks to H2 4X4!
Old 01-08-2003, 02:44 PM
HummerH2 HummerH2 is offline
HummerH2 is off the scale
Thanks!
New York Rules
Old 03-27-2003, 04:16 AM
alaskahummer alaskahummer is offline
alaskahummer is off the scale
thanks so much, this was easy and I was finished reprogramming in fifteen seconds.
hs
Old 10-26-2005, 06:35 PM
BumM3r's Avatar
BumM3r BumM3r is offline
BumM3r is off the scale
Will these instructions work on my 05 H2?
TIA
05 Pewter Lux SUT, spare tire delete
Old 10-27-2005, 02:26 PM
Hummertech is off the scale
Yes, it works on just about everything GM has made on it's truck lines since 02.
