10-16-2005, 09:58 PM
You can fix your UCP at home instead of replacing it.
Ed told me about this and the website at the Penns Cave event this weekend.
It's genius, I wish I had thought of it myself, it's simple, and works.
Here's the link: http://www.flashoffroad.com/features...ercarriage.htm
Check it out. If you offroad, you'll probably need it sooner or later.
Shipbldr...
Shipbldr...
10-16-2005, 10:43 PM
That's a lot of effort for such a simple fix.
Take off your UCP and lay it on the ground with the front edge on a 2-3' long piece of 4X4 wood. Then run the front tire of your H2 up each of the three bars. Don't worry- by using the 4X4 piece of wood you'll only be able to bend the bars so far. Depending on how badly your UCP is bent, you might have to do it a couple of times.
I've done this a few times, and it works perfectly.
10-16-2005, 11:01 PM
Thanks DRTYFN!
After this reshaping... Do the bolt holes still line up without too much trouble...?
10-19-2005, 02:00 AM
Wishful thinking but can I do this with my bent cross bar???  Damn rock!!
Ginger
