Old 12-30-2005, 03:24 AM
Andre Andre is offline
Andre is off the scale
Well woke up the other morning and there was trans fluid in the snow...turns out my housing is cracked....
Old 12-30-2005, 09:43 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Andre:
Well woke up the other morning and there was trans fluid in the snow...turns out my housing is cracked.... </div></BLOCKQUOTE>
You do mean transmission.... not the transfer case, right?
I ask because it uses basically the same design transfer case as my Yukon did and I had to replace it 3-4 times because it was cracking. (turned out the motor mounts were causing it)
Anyway, the reason I ask is because only one half of my H2 transfer case was broken so when I replaced it, I still the other half.
Mark
Old 12-31-2005, 04:26 AM
had a shift solenoid go bad..so they changed it..well i guess they lost a bolt for the trans oil pan and they put a longer one in, was hitting the housing and it cracked right where the bolt was hitting.
by the way, seen your new rims...nice
what make and size are the rims and tires
