Old 12-05-2005, 06:26 PM
DWPC DWPC is offline
DWPC is an unknown quantity at this point
My biggest gripe with the H3 has been a creaking noise from the hood thats almost constant when moving. If I jiggle the closed hood I hear it, but can't find it when the hood's open.
'06 H3 Adventure (9/2005-1/2013)
Old 12-05-2005, 07:05 PM
Hummer eh! Hummer eh! is offline
Hummer eh! is off the scale
have you made sure every bolt you can find is tight. i had to tighten various screws on my vehicle when i got it. rear fender flare, hood, etc.
Old 12-05-2005, 07:07 PM
H3O H3O is offline
H3O is off the scale
I had the same problem. I isolated the sound as coming from 2 rubber stoppers or grommets. The stoppers can be seen to the left and right with the hood in the open position. I sprayed with 303 Aerospace Protectant you can use another lubricant that will soften the rubber. While in the engine compartment I also treated the weather stripping and anything else coming in contact with the hood in the closed postion. To test with the hood closed I climbed on the drivers step and while holding on to the crossover bars (luggage rack) rocked the H3 iup and down to recreate the squeak and to test whether more lubricating treatment was necessary.
