Old 05-20-2005, 02:54 AM
I'm having a system built with a 10.4" touchscreen monitor. It will I think remove radio completely from the loop. If it works the way i have seen it and understood it. Will run software that use H2 GPS for NAV and has XM located remotely. Well a bunch of other stuff. When We get it farther along hopefully will have more soon. Has a bunch of stuff it does. Will have oil pressure, water temp. and other vitals on touchscreen hopefully. Trying to swee how many things You can follow on the system. I'm asking about boost and other forced induction info at the finger tip. Fun to think about and hope it works. I know a 7" that is running now with allot of functions. I'm asking for a few more functions and a 10" screen. Do not really need it but, want it. It will look good for shows. I can set a program to run loop at show telling who the sponsors are and what kind of stuff I have in the Mall Gueen. Looking like it will be with a kit most could install or worst have a shop customize the center console and You have all the components matched up with software to work together. That way You would not have to go out and hunt down what will work together. Allot of stuff are not compatible. Hopeful can at least solve that part. Will look at having consoles premolded to just replace the factory console. No cutting and shaping. Hopeful just plug and play run a few wires. Same is trying to be done with HUD. Molded replacement for the panel over the gauge cluster that will have projector at proper angle and have HUD controls installed. Hoping to have the pins traced for the serial feed to build a plug that can be just connected after replacing factory cluster top.
Hoping it will all work. Doing 2 projects at once will slow it down a little but, just began to ask and look into the 10" touchscreen thing.
Well all that are interested will be informed as soon as we can.
TAZ
