01-09-2003, 12:02 PM
Need instructions how to take the inner plastic door panel off, so I can furnish the door pockets.
The way it is now leads to too much rambling of stuff put there.
Tried pulling, but stopped at that, because afraid it would brake.
The little screw behind the door handle only leads you to the locking mechanism, I guess.
Kuhl to the rescue please.
JCJ
PS First I wanted to wait the Service Manual to come out at Helminc.com, but lost patience.
JCJ
01-09-2003, 02:06 PM
JCJ, I had the same problem, but lined the door pockets with some of that anti-slip stuff sold for motorhome drawers. It comes in many colors and is not noticeable. AL
"Follow the white rabit" .. Matrix 1999
\"Follow the white rabbit...\" Morpheus 1999....... It is finished.
01-09-2003, 04:08 PM
I found some dark brown adhesive-backed felt drawer lining stuff at Home Depot. It's a really dark brown, so it looks pretty good.
01-09-2003, 04:38 PM
SMA is faxing me instructions do to this. I'm looking at replacing my door handle covers because of the easy of thief with the cheap plastic one. I can see about scanning it in and posting it here.
H2SUT.com
Regards,
David
H2SUT.com
Red metallic, Lux package, Poron backup sensors, throttle body by-pass, Independent dual DVDs, Volant air box, DRL mod, chrome hood handles and latch.
01-09-2003, 08:51 PM
Well, got the fax on replacing the billet door handle. Didn't say anything on exactly how to remove the trim panel. It just say 'Remove door trim panel'.
For those who are thinking about swaping out to the billet door, it's compliated...here are the first few steps:
1 - Remove door trim panel
2 - Remove water deflector
3 - Remove window <------------!!!!
4 - Loosen clamps securing window to the window module
5 - Remove outer window belt sealing strip
6 - Remove window through the bottom of the window frame
7 - disconnect outside door handle rod
8 - disconnect lock cylinder rod
etc...
There's also drilling and grinding that has to be done.
The illustrations are minimal at best. You'll have to be an expert mechanic to tackle this one. It's not one you can DIY that's for sure.
H2SUT.com
Regards,
David
H2SUT.com
01-11-2003, 01:16 AM
Ooooo, that whole billet door thing sounds nasty. Quite a bit of work I'd say.
To remove door trim, remove the screw behind the handle. Remove the silver painted plastic plate the screw held on. you will find two more screws that hold the bracket for the pull handle (the leather wrapped one) to the door. Remove those. I believe there are 7 two stage plastic fasteners that simply hold the trim to the sheet metal. Your dealer or a body shop has a "special tool" they use to remove them. It is simply a skinny crow bar they wedge between the edge of the trim and the sheet metal and "twist" or "pry" the trim off in the attachment areas .... if you pry a little you can kind of "see" where the trim stays stuck to the sheet metal. Once you pop one or two clips, you can get your fingers in there and just pull the panel away from the door.
A MAJOR word of caution here. DO NOT pull on the top edge of the map pocket to remove the door. It WILL crack and cannot be repaired. It is heat staked (permanently attached) and cannot be repaired if broken. You will need to replace the whole door trim panel.
The clips, as I said, are "two stage". Half of the clip is designed to be removed with the trim and the other half is designed to stay in the sheet metal. Do not be alamed because it seems that the clips are "broken", they are not.
Simply reverse the operation to re-install. There are two molded in plastic locators on the back of the door that protrude quite far. Start both of these and all of the clips should find their home naturally.
The procedure is the same for both front and rear doors.
Roadsigns are just a suggestion ... like pants
Founding member of the \"No Hummer Krew\"
01-11-2003, 03:53 AM
I did not know those are leather, I have to go to the garage to smell it. What else is leather beside seats, top of center console, handles?
"pull handle (the leather wrapped one) to the door."
I saved your instruction for possible future use.
01-11-2003, 11:54 AM
So do I understand correctly, that for the sole purpose of sticking noise reducing lining in the map pockets, it is no use taking the door panel apart?
Because the map pocket is "permanently attached" to the door trim, so to speak.
I'd thought the inside wall (towards cabin) of the map pockets were attached by similar clips, which would appear after taking the door trim off.
So now I'll have to be really carefull with that glue gun and/or double-sided advesive tape, when sticking those pieces of anti-slip sheets and even more careful when cutting them off at the edges.
ER experience comes in handy now.
01-11-2003, 11:56 AM
More leather parts:
Steering wheel, passenger roller coaster bar, shifter handle, your pants.
01-11-2003, 11:58 AM
So...you use glue guns and double-sided adhesive tape in the ER there in Aruba?
I'd love to see some of those reports that you dictate!!!
01-11-2003, 12:20 PM
Actually that was the Voodoo ER in downtown Kingston Jamaica.
Luckily we get so much US tourists here that we can afford the regular stitching material.
01-11-2003, 12:29 PM
Whew !!! My DH's company may be sending him out to Aruba at some point in the future...so it's good to know that you use the good old fashioned Vicryl instead. Had me scared there for a minute!
01-11-2003, 01:58 PM
Haha, I have the whole forum sniffing their vehicles  . JCJ is correct on all counts of leather. He is also correct that removing the door panel will not make access to the map pocket any easier.
Pull handle - screwed on
Silver bezel around pull handle - heat staked on
Inside door release handle - attached to the door sheet metal
Courtesy lamp - snapped in
Switch escucheon - snapped in
Map pocket - heat staked on
Upholstered door bolster - heat staked on
Armrests - heat staked on
This is all I can think of right off the top of my pointed head. If anybody has a question about how a certain component is attached, please post it up and I'll try to get an answer.
01-11-2003, 06:45 PM
OK, Kuhl, your info is getting really helpful now.
I have been thinking about replacing the map pockets on the fron doors with a custom assembly that contains a row of smaller (6.5") speakers.
Do I undertstand you correctly that there is no way to ake them off?
01-11-2003, 07:03 PM
Uh, my info wasn't helpful before  ???
The door speaker is actually mounted in a molded plastic "basket" bolted to the door sheet metal. The speaker is not mounted to the trim. The speaker grill on the trim panel really just "covers" the speaker.
BTW, the grill portion itself simply has some tabs that are inserted into slots on the trim. It is metal and the tabs are simply bent over to retain them to the door panel. Would be very easy to remove with the door panel off if you ever wanted to.
Founding member of the "No Hummer Krew"
01-11-2003, 07:07 PM
Sorry, just reread your question and it seems you just want to remove the map pocket from the door trim panel. If you remove the panel from the sheet metal and filp it over, you will see where some tabs have been pushed through the panel to attach the map pocket. They will appear to be melted ... and that is the attachment method. Some work with a dremel should give you the ability to remove the map pocket with no visible damage to the front side of the door ....
.... keep in mind you will see several little slots where the tabs for the map pocket used to reside.
01-11-2003, 07:24 PM
Sorry I can't be more helpful but I don't exactly have anything to take pictures OF  .
What happened exactly, and where on the panel did you think you were going to "break" something??? If you can describe what you are doing, maybe I can help.
Did you remove all 3 screws???
01-11-2003, 09:52 PM
Yup, removed all 3 screw and plate behind door (opening) handle. Then tried pulling on door trim panel holding it at the lower armrest.
I heared a few snapping sounds when the front part of the arm rest gave a little way, but still just too little compared with the loudness of the sound.
My question now is:
What includes "door panel".
IOW what comes off when pulled and comes loose after loosening the clips?
Does the panel include the arm rest (and switche[s]) and (upholstered) door bolster?
Thank you so much 4 your patience.
