Old 04-03-2008, 08:39 AM
RenoMoe's Avatar
RenoMoe RenoMoe is offline
RenoMoe is off the scale
Default Lost all power to my front passenger door?????
I seem to have lost all power to my right front passenger door. I took the door apart and checked all fuses and didnt find anything out of place or blown. Any suggestions would be greatly appreciated.
03 H2
03 Black Lux
6\" Fabtech Lift
37\" Toyo MT\'s
AMP Wheels
http://i277.photobucket.com/albums/k...fe30ffbfdf.jpg
Old 04-04-2008, 02:05 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Default Re: Lost all power to my front passenger door?????
Check the wiring between the door and the body , the wires sometimes break from repeated opening & closing over the years
Old 04-04-2008, 11:43 PM
RenoMoe's Avatar
No luck.....I the took the door panel part and everything look fine. Nothing on the door works, the dome lights don't even come on when door is opened, no locks, mirror control, seat heater etc....
03 Black Lux
6\" Fabtech Lift
37\" Toyo MT\'s
AMP Wheels
Old 04-05-2008, 12:07 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Did you check the mbec 1 fuse in the underhood electrical center. There is also a circuit breaker in the relay block under the left side of dash.
Old 04-05-2008, 02:10 AM
RenoMoe's Avatar
the fuse was fine, but I couldn't locate the reset switch you mentioned. I looked for it under the fuse block but no luck. I just think its odd how just the right front door is powerless. This is so frustrating!!!
03 Black Lux
6\" Fabtech Lift
37\" Toyo MT\'s
AMP Wheels
Old 04-05-2008, 02:38 AM
HUMTECH's Avatar
heres the schematic, hope it helps
Old 04-05-2008, 03:20 AM
RenoMoe's Avatar
I pulled the silver '25 LT Doors' circuit breaker and still problem exist. Question: If this circuit breaker is bad will it cause just one door to lose all power
03 Black Lux
6\" Fabtech Lift
37\" Toyo MT\'s
AMP Wheels
Old 04-05-2008, 09:00 AM
HUMTECH's Avatar
LT is for the drivers door, it is unlikely that a circuit breaker will fail just worth a try. The rt breaker is for the right door
Old 04-05-2008, 10:50 PM
RenoMoe's Avatar
Thanks for the help.....still can't find the issue. I check the circuit breakers, fuses and wiring and still no power to any of the systems on the front passenger door.........next solution will be dealer.....I was hoping to avoid that one
Any other ideas????
03 Black Lux
6\" Fabtech Lift
37\" Toyo MT\'s
AMP Wheels
Old 04-06-2008, 08:44 PM
HUMTECH's Avatar
So, do you have power into the front right switch assembly. Is the ground good? if both of these are good. Check for power and ground signals out of switch assembly, if nothing out you will need the switch assembly(passenger door module)
Old 04-07-2008, 12:30 AM
RenoMoe's Avatar
None of the controls work on the right front door - assembly is completely inoperable
The drivers door controls all work with the exception of the right front door (passenger) switches.....window, locks, and mirror.....
I have no power to the right front door, seat heater switch, window, locks, mirror.....
Do you think the switch assembly on the passenger door is bad? Will this cause the switches on the drivers door that control the right front window, mirror and locks not to work?
Thank for all your help!!
03 Black Lux
6\" Fabtech Lift
37\" Toyo MT\'s
AMP Wheels
Old 04-09-2008, 03:32 AM
yncy515 yncy515 is offline
yncy515 is on a distinguished road
i had experienced that before the mechanic replaced some of the wires relay and it only cost me around $5. lets hope its just the same with mine..
_________
Audi S4 Brake Pads rules
Audi S4 Brake Rotors knows what you need.
Old 04-11-2008, 02:08 PM
pdsq99f4 pdsq99f4 is offline
Are you checking for power at the door with a test light or are you just saying it doesn't have power because nothing works? You need to check with a test light for power at the 2 places and the one ground. I had one the other day that ckt4240 was rubbed through behind the rf door speaker. Hope this helps.
