Old 11-20-2002, 10:36 PM
SunsetShannon SunsetShannon is offline
SunsetShannon is off the scale
Tandem Pull
[This message was edited by SunsetShannon on November 20, 2002 at 04:57 PM.]
- Shannon
\'98 Black OpenTop H1
Former Sunset Orange H2
http://www.geocities.com/rottinmom/index.html
Viva la E.C.H.O.!
Tandem Pull
- Shannon
Viva la E.C.H.O.!
Old 11-20-2002, 10:39 PM
- Shannon
Viva la E.C.H.O.!
Old 11-20-2002, 11:21 PM
Daft_Punk Daft_Punk is offline
Daft_Punk is off the scale
Your front tires are just digging in under their weight
Old 11-24-2002, 08:25 PM
HeeHaw HeeHaw is offline
HeeHaw is off the scale
Looks like fun!!!!!!!!!!!!!!!!!
HeeeeeeeeHawwwwwwwwwww
Old 11-26-2002, 03:59 PM
SJ SJ is offline
SJ is off the scale
OK, I'm new to Hummers, so don't jump on me for this question:
I thought pulling in reverse was a bad idea due to its stress load on the drivetrain, which is not designed for greater torque in reverse drive.
I always attached tow straps to the rear frame points of my 4 x 4s and pulled forward. Is the Hummer a tougher breed to where towing in reverse is not an issue?
Obviously you can winch from the front by setting the parking brake and tranny in neutral, but that's a situation of stationary pulling where the extraction vehicle acts as an anchor.
________________________
\'03 H2 [Sold]
\'03 Chevrolet Silverado Z71, 6\" Rancho Lift, Rear Factory Locker, 35\" ProComp MTs
http://www.smiliegenerator.de/smiley...miley-9839.png
Old 01-11-2003, 07:56 PM
Mike97ZJ Mike97ZJ is offline
Mike97ZJ is off the scale
I've actually been told the same thing.
Only reason I can see for pulling in reverse are that you can better see what you are doing, and that in some automatic transmissions, the lowest gear is reverse.
I guess sometmes it can't be avoided, if the guy on the trail in front of you is stuck, and you can't turn around. Then you'll HAVE to tug him out in reverse.
1997 Grand Cherokee TSi
It\'s got some lift, skids, and rock rails, among other things.
*member of the \"No Hummer Krew\"*
