Old 06-01-2005, 08:50 PM
Wet hummer Wet hummer is offline
Wet hummer is off the scale
I have a 2005 hummer h2. I have been experiencing water leaking in through the garage door opener control pannel. The truck has been back to the dealership 4 times now. The first two times, they allegedly fixed the leak. Now the past two times, they claim they can's find the problem, yet I am still experiencing a water leak. I have spoken to the delaership, and also to the manufactor. Neither one has been helpfull as of now. Basically, they tell me i need to wait for an engineer to look at my truck. Until then, i must carry a rag, and dry all the water, and hope that nothing gets damaged any further. Does any one have any suggestions?
Old 06-01-2005, 09:14 PM
funpilot funpilot is offline
funpilot is off the scale
This is not a new problem....search the forum. What I have read indicates that leaks are fixable.
Old 06-01-2005, 09:16 PM
Arizona Hummerboy's Avatar
Did you check your roof marker lights seal?
Old 06-02-2005, 05:54 AM
Mully Mully is offline
Mully is off the scale
Not that familiar with my hummer yet but my porsche has drains that occasionaly get clogged. Just a thought. Hope you don't have a lemon!
2003 Black Lux
2001 Disco SE7
1995 Porsche 911
Old 06-02-2005, 11:01 AM
VTSTOMPER is off the scale
Sounds like marker lights...
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 06-02-2005, 11:52 AM
the dealer allegedly put silicone around the lights, but they are still leaking. thanks for the input.
Old 06-02-2005, 11:58 AM
wonder if they used the right stuff? Also could be the moonroof drains, or on a slim chance the windshield gasket.
Old 06-02-2005, 01:34 PM
Dan Dan is offline
Mine did the exact same thing. One time after a heavy rain the water streamed in, down the dash, and right into the NAV slot. Messed up the screen for a few days until it dried out.
They had a hard time finding the entry point but tracked it to a split seal under one of the marker lights. New light and silicone on them all. No problems since.
Old 06-02-2005, 06:57 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mully:
Not that familiar with my hummer yet but my porsche has drains that occasionaly get clogged. Just a thought. Hope you don't have a lemon! </div></BLOCKQUOTE>
I should clarify. The drains are for my sunroof. I imagine the Hummer has a similar set up. Take an air hose and "gentle" blow them out.
2003 Black Lux
2001 Disco SE7
1995 Porsche 911
Old 07-28-2005, 07:04 PM
After all the complaining, and the after my truck leaking SIX times, GMAC decided to give me a new truck. 2005 SUT, Thanks for all the input
Old 07-28-2005, 07:15 PM
LoLo's Avatar
LoLo LoLo is offline
LoLo is off the scale
...take it to the carwash and make sure IT doen't leak!
Glad you got things worked out... we had a "lemon" Jeep way back in '89 (before I knew better! ) that we never got resolved! I finally traded in the P.O.S. and never looked back!
___________________
05 Desert Sand H2 Adv
