03-19-2003, 10:24 PM
I was considering buying this filter and stainless tube set up. I spoke with K&N and they have nothing in the pipe for at least 90 days.
Does anyone have this? Was it easy to install? Did it make any difference whatsoever?
thanks.
thanks.
03-20-2003, 02:24 PM
I have had it for about 3 weeks now. It is easy to install and works great. Gas milage so far is about a 1-1.5 mpg better depending if I want to hear the throaty sound. I bought it at the Rev Shop
www.therevshop.com
03-20-2003, 05:40 PM
Thanks.
Do any factory parts have to be modified and did you get better throttle response?
California Yellow LUX ....
03-20-2003, 08:31 PM
No it bolted on directly just as the instructions said. Throttle response is better but I want a programmer to go with it. The filter is larger than any I have seen. The end has an inverted cone for more surface area. While I had it apart I bypassed the coolant line in the throttle body. This way the throttle body is cooler thus air stays cooler. It is simply a 1/4 inche Dia. coulper that each hose slide over and applied hose clamps. The Rev Shop also has free ground service for shipping.
03-21-2003, 03:05 PM
ONE QUESTION WHY IS THE COOLANT LINE IN THE THROTTLE BODY IN THE FIRST PLACE VERSES NOT. I SEE THE POSITIVE YOU SPEAK OF,SO WHY IS IT NOT THAT WAY IN THE BEGINING
03-21-2003, 04:55 PM
The coolant flow is there to keep your throttle body from freezing up in cold, damp weather.
Personally, I don't think it is worth the trouble. A throttle body that freezes up can cause all sorts of problems.
Klaus
03-22-2003, 02:28 AM
It is for freezing potential as well as better emission ratings. I have always used 160 degree thermostats in my street rods. The newer engines run a 190 degree t-stat. The hotter the engine is the more emissions it burns off. There fore I have a 160 t-stat and coolant bypass. I live in the Houston area winter here is about 28 degrees over a 3 hour period for 1 night.
03-24-2003, 02:37 PM
I would just caution you that the outside temperature does not have to be below freezing for a throttle body to freeze up. Keep in mind you are dealing with low pressure on the intake. Cool, moist air is all it needs to freeze up.
Klaus
