Old 10-14-2004, 05:23 PM
Patriot Patriot is offline
Patriot is off the scale
OK…stupid question…
In what orientation do you mount rear shocks?
I have the new Bilsteins all ready to go.
I called them and they said you should be able to read the label. That sounds good but NOT very definitive.
I figure they should go boot/rod up. This would make label read correctly as well.
The reason I ask is that some of the remote reservoir models have rod down. These are not that model but I just want to make sure…
OK…stupid question…
OK…stupid question…
Old 10-15-2004, 12:17 AM
No one???
Come on guys...I want to install these this weekend.....
Old 10-15-2004, 12:40 AM
Circuitguy
Rod with boot up and the shock body down. Easy one! BIG-C
Old 10-15-2004, 12:49 AM
HGW HGW is offline
HGW is off the scale
My rear King reservoirs are body up, shaft pointing down---it is the only way they will fit and they work great bec. they were designed to function that way.
You need to call your manufacturer and ask again. Shaft pointing up or shaft pointing down---forget about how the shock reads.
Old 10-15-2004, 02:07 AM
discofever discofever is offline
discofever is off the scale
Circuitguy is correct... My Bilsteins are installed the same way.
Old 10-15-2004, 03:42 AM
HUMMERS HUMMERS is offline
HUMMERS is off the scale
If the part number is BE5-6647-H5 then you have the 5100 series.
The orientation should be rod up and body down.
Old 10-15-2004, 04:04 AM
JohnB.GWU. JohnB.GWU. is offline
JohnB.GWU. is off the scale
when installing shocks, you must take into consideration that when the heat builds up, the fluid inside will become frothy. If you have the shocks mounted with the rod facing up, all this foamy fluid is EXACTLY where the piston is at rest, and the initial stroke of the shock will be poor as it passes through this fluid. WHat model bilstein do you have,,is it gas charged etc...This is why when you mount fluid shocks, they must go body up...look into it for a smooth and predictable ride
John R. Benda
03\' Yellow Adv- Sold
04\' White H2 Lux - Sold
05\' Yellow Lux - BACK TO YELLOW BABY!!!
04 S55 Benz w/Brabus Tuning
Old 10-15-2004, 09:40 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by HUMMERS:
The orientation should be rod up and body down. <HR></BLOCKQUOTE>
Yes, that's the model....
Based on what the Mfg said and the others here who have the same shocks...it will be rod up!
Thanks all for the replies
