Old 01-15-2005, 01:07 PM
GeorgeSSSS's Avatar
GeorgeSSSS is off the scale
I don't have winch (yet) but it seems to me that it makes more sense to have a multi-mount set-up rather than a fixed winch because you can put the multi-mounted winch in the garage and keep it clean when you aren't off roading and if you need to winch yourself out of trouble you can put the multi-mount in the rear hitch if that's the best solution. I'd like to hear some experinced winchers' pros and cons on multi-mount v. fixed winch before I make a decision (i.e., spend money).
Thanks,
George
GeorgeSSSS's Avatar
Thanks,
George
GeorgeSSSS's Avatar
Thanks,
George
Old 01-15-2005, 01:25 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
I prefer the multimount over the fixed because of the flexibility from front to rear, and taking it with me, on other vehicles when I'm not in my H2. ie. My buddies 2500HD has the connectors for the winch, but has no winch yet.
It's easiest for me, but some prefer the fixed mount for the security and a little more stable.
I think it's all a matter of opinion!
Ric-H2
www.meatspin.com
Old 01-15-2005, 02:45 PM
10 MPG 10 MPG is offline
10 MPG is off the scale
RIC-H2, can you explain further, security as in not getting stolen? stability in operation? Thanks.
Old 01-15-2005, 04:40 PM
RIC-H0's Avatar
I've yet to have mine stolen, but if someone were to really want it, they could break the pin lock and take it off the front of my vehicle.
As far as Stability goes...with the multi-mount, the whole winch is resting on the receiver, and not mounted to the frame. I have exceeded the limits on the capacity of my winch a time or 2, but the whole time, I wasn't concern with the winch giving way as much as the receiver mount bolts breaking on me.
Just my 2 cents worth!
But I will continue to use my multimount!
I actually leave my winch on 100% of the time, because you never know when you may need it.
It's kinda like steel toes on a workboot, kinda inconvenient at times, but really nice to have when something causes you to need them!
Ric-H2
www.meatspin.com
Old 01-18-2005, 02:27 AM
RI Hummer RI Hummer is offline
RI Hummer is off the scale
How do you have a front plate and a winch in states that require a front winch?
Old 01-18-2005, 02:28 AM
I mean front plate of course, Must be too late for me.
Old 01-18-2005, 04:46 AM
RIC-H0's Avatar
I normally don't have the front plate on mine, even though per state law it is required.(Great! I'm probably going to get a ticket now!)
The neatest way to mount your plate is, to bolt 2 pair of mag light mounting brackets to your plate(2 on top & 2 on bottom of plate), and then simply attach the plate to your roller fairlead. You can take your plate off and on as needed, and it keeps your fairlead nice and bug free at the same time!
Ric-H2
www.meatspin.com
Old 01-18-2005, 03:07 PM
I prefer the MM. Can put it on the rear, can still use the front receiver, etc.
