Old 03-06-2006, 11:33 AM
Plexinator's Avatar
Plexinator Plexinator is offline
Plexinator is off the scale
is the radio locked, i got a new one on ebay.
is it simple to change the both?
what will happen?
.............thanks...........arne
Old 03-06-2006, 01:40 PM
Plexinator's Avatar
the VIN code is well known
Old 03-06-2006, 02:08 PM
md_sailor's Avatar
md_sailor is off the scale
The Radio needs to be Reprogrammed at the dealer to recognize the Vin of your vehicle. Factory head units are paired with their vehicles. You also need to be sure the unit works with your vehicles amp setup. Use the SEARCH Button for more info on this process.
Old 03-06-2006, 02:10 PM
md_sailor's Avatar
Actually any GM Shop with a TECH II unit can do the job..
Old 03-06-2006, 03:46 PM
md_sailor's Avatar
Originally posted by PhilD:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Plexinator:
So why did you ask if you already knew that it was VIN locked? </div></BLOCKQUOTE>
Phil, I gave him the benefit of the doubt, somthing may have been lost in translation.
Old 03-07-2006, 12:43 AM
saleen779 saleen779 is offline
saleen779 is off the scale
i ordered a '04 navigation head unit for my '03 that should be here wednesday. i do have the bose option in my rig. i called the dealership and they told me they would unlock the nav unit but wouldn't install it. do you think i'll have any problems with the amp? or is it a pretty straight forward install that any custom stereo shop can do? and yes i did a search and there is way too much info to sift through and not enough time. thanks!
H2 for life!
Old 03-07-2006, 01:25 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I swapped in A nav unit in an 04 and it plugged right in, same harness and connectors just needed to add A gps antenna to operate the nav system. And program once install is complete.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-07-2006, 01:52 AM
Klaus's Avatar
Klaus Klaus is offline
Cliff Notes:
'03s have a LUX amp, so you must use a NAV unit made to work with a LUX amp. If you get the wrong NAV unit, you will get no audio.
'03s also have no VSS signal wire in the head unit connector, so you will have to add one.
Old 03-07-2006, 05:16 PM
Klaus, anyway to tell if the nav unit is made to work with a lux amp by looking at it? also, just so i get this straight, it needs to be programmed AFTER the install?
H2 for life!
Old 03-08-2006, 01:48 PM
does anyone know if i need to have the nav unit unlocked before or after install???
H2 for life!
Old 03-08-2006, 02:22 PM
Klaus's Avatar
Some of the NAV units have "LUX" or "PREMIUM" listed on the part number label. If not, the part number will have to be used to look up which system it is made for.
When we say "programming" we are referring to the VIN lock. The first time a brand-new NAV unit is powered up, it stores the VIN of the vehicle it is installed in. It then compares the stored VIN number in memory to the current VIN each time the unit is powered up. As long as they match, everything is fine. If they do not, the unit will display "Theftlock Activated". At this point, the vehicle will have to be connected to a Tech2 diagnostic unit to command the NAV unit to "relearn" the VIN from the current vehicle.
So yes, the NAV unit needs to be installed first, before it can be unlocked.
Old 03-08-2006, 02:36 PM
Klaus, once again thank you! i have no idea what i'd do without this forum and it's members!
H2 for life!
