03-25-2006, 01:32 AM
Maintenance, Recalls and TSBs
TSB Quick Look
2006 HUMMER H3 4dr SUV 4WD (3.5L 5cyl 5M)
VISIBILITY:REAR WINDOW WIPER/WASHER
EXTERIOR LIGHTING:TAIL LIGHTS
SEAT BELTS:FRONT:ANCHORAGE
OTHER
POWER TRAIN:AUTOMATIC TRANSMISSION
TIRES
ELECTRICAL SYSTEM
STRUCTURE:BODY
STRUCTURE:BODY
EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
OTHER
OTHER
ELECTRICAL SYSTEM
POWER TRAIN:TRANSFER CASE (4-WHEEL DRIVE)
TIRES
ELECTRICAL SYSTEM
POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:COLUMN SHIFT
SUSPENSION
ELECTRICAL SYSTEM
SUSPENSION
EXTERIOR LIGHTING
ELECTRICAL SYSTEM
ELECTRICAL SYSTEM
SERVICE BRAKES, HYDRAULIC:ANTILOCK
POWER TRAIN
SERVICE BRAKES, AIR:ANTILOCK:INTERCONNECTING ASSEMBLY(WIRING)
POWER TRAIN
ENGINE AND ENGINE COOLING:ENGINE
ELECTRICAL SYSTEM
EXTERIOR LIGHTING:BRAKE LIGHTS:SWITCH
TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
ELECTRICAL SYSTEM:WIRING
ELECTRICAL SYSTEM:WIRING:FRONT UNDERHOOD
ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Component Description:
1. VISIBILITY:REAR WINDOW WIPER/WASHER Bulletin Number: 05115
Bulletin Date: DEC 2005
Vehicle: 2006 HUMMER H3
Summary:
REAR WASHER PUMP INOPERATIVE. ( NHTSA ITEM NUMBER - 10018952 )
2. EXTERIOR LIGHTING:TAIL LIGHTS Bulletin Number: 050842017
Bulletin Date: NOV 2005
Summary:
TAIL LAMP HOUSING SEPARATES FROM TAIL LAMP RETAINERS (REPLACE TAIL LAMP HOUSING RETAINER). ( NHTSA ITEM NUMBER - 10018694 )
3. SEAT BELTS:FRONT:ANCHORAGE Bulletin Number: 990940005B
Summary:
SEAT BELT EXTENDER AVAILABILITY. ( NHTSA ITEM NUMBER - 10004728 )
4. OTHER Bulletin Number: 000089008E
Bulletin Date: OCT 2005
Summary:
SOME CUSTOMERS MAY WANT TO TOW THEIR VEHICLE BEHIND ANOTHER VEHICLE WITH ALL FOUR TIRES ONT HE GROUND. THIS BULLETIN PROVIDES INFORMATION REGARDING RECREATIONAL (DINGHY) TOWING FOR CERTAIN VEHICLES INCLUDING 1988-2004 CHEVROLET AND GMC LI ( NHTSA ITEM NUMBER - 10005527 )
5. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 010730030A
Summary:
DIAGNOSTIC INFORMATION ON HARSH 1-2 UPSHIFT. 2001-2002 PASSENGER VEHICLES AND LIGHT DUTY TRUCKS. ( NHTSA ITEM NUMBER - 627729 )
6. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 010730036D
Summary:
DIAGNOSTIC TIPS FOR DIAGNOSTIC TROUBLE CODE P0756. 2006 AND PRIOR PASSENGER VEHICLES AND LIGHT DUTY TRUCKS. ( NHTSA ITEM NUMBER - 10000758 )
7. TIRES Bulletin Number: 050310012
Bulletin Date: SEP 2005
Summary:
USE RECOMMENDED TIRE MOUNTING LUBRICANT TO PREVENT TIRES FROM SLIPPING ON CHROME WHEELS. 2006 AND PRIOR PASSENGER CARS AND LIGHT DUTY TRUCKS (INCLUDING SATURN). REPLACES 93-3-6, 93-3-11, 93-3E-63, 93-3E-103, 93-169-3E, AND T-93-93. ( NHTSA ITEM NUMBER - 10017572 )
8. ELECTRICAL SYSTEM Bulletin Number: 050842012
Summary:
TRAILER PARK LAMPS, TURN SIGNAL, STOP LAMPS OR TRAILER BRAKES INOPERATIVE. ( NHTSA ITEM NUMBER - 10017829 )
9. STRUCTURE:BODY Bulletin Number: 050851005
Summary:
CLOUDY SPOT IN PAINT AFTER PROTECTIVE COVERING IS REMOVED (HEAT AREA). 2005 - 2006 GM PASSENGER CARS AND TRUCKS. ( NHTSA ITEM NUMBER - 10017847 )
10. STRUCTURE:BODY Bulletin Number: 020898001A
Summary:
GENERAL GUIDELINES FOR REPAIR SHOPS THAT WISH TO USE ADHESIVE BONDING OF EXTERIOR PANELS AS AN ALTERNATIVE TO MIG WELDING. 2006 AND PRIOR GM PASSENGER CARS AND TRUCKS (INCLUDING SATURN) AND 2006 AND PRIOR ISUZU LIGHT AND MEDIUM DUTY TRUCKS ( NHTSA ITEM NUMBER - 634326 )
11. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Bulletin Number: 040844009A
Summary:
XM DIGITAL RADIO RECEIVER ORDERING PROCESS. ( NHTSA ITEM NUMBER - 10008482 )
12. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 010730002D
Summary:
MALFUNCTION INDICATOR LAMP (MIL) ON, TRANSMISSION STUCK IN THIRD GEAR, INSTRUMENT CLUSTER INOPERATIVE. ( NHTSA ITEM NUMBER - 619393 )
13. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL Bulletin Number: 000604033
Summary:
I/M READINESS AS PART OF EMISSION INSPECTION AND MAINTENANCE PROGRAM FOR OBD II VEHICLES. ( NHTSA ITEM NUMBER - 10017832 )
14. ENGINE AND ENGINE COOLING Bulletin Number: 050604060
Summary:
POWERTRAIN CONTROL MODULE (PCM), ENGINE CONTROL MODULE (ECM), TRANSMISSION CONTROL MODULE (TCM) DIAGNOSTIC TROUBLE CODE(S) (DTC)(S) P0601, P0602, P0603, P0604, P1621 SHARED IN MULTIPLE MODULES. ( NHTSA ITEM NUMBER - 10017826 )
15. ENGINE AND ENGINE COOLING Bulletin Number: 050604055
Summary:
SERVICE ENGINE SOON (SES) LIGHT ON, DIAGNOSTIC TROUBLE CODE(S) (DTC) P0442 SMALL EVAPORATIVE EMISSIONS (EVAP) LEAK AND/OR P0455 LARGE EVAP LEAK. ( NHTSA ITEM NUMBER - 10017822 )
16. OTHER Bulletin Number: 050089062
Summary:
CAR AND TRUCK FIX IT RIGHT THE FIRST TIME ISSUES AND BULLETINS RELEASED WEEKS OF SEPTEMBER 5, 2005 AND SEPTEMBER 12, 2005. 2006 AND PRIOR PASSENGER CARS AND TRUCKS (INCLUDING SATURN). ( NHTSA ITEM NUMBER - 10017839 )
17. OTHER Bulletin Number: 050089060
Summary:
CAR AND TRUCK FIX IT RIGHT THE FIRST TIME ISSUES AND BULLETINS RELEASED WEEKS OF AUGUST 22, 2005 AND AUGUST 29, 2005. ( NHTSA ITEM NUMBER - 10017838 )
18. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Bulletin Number: 030844022
Summary:
PARTS RESTRICTION ON ORDERING XM DIGITAL RADIO RECEIVER. 2002-2004 CARS AND TRUCKS. ( NHTSA ITEM NUMBER - 10005170 )
19. ELECTRICAL SYSTEM Bulletin Number: 050844027
Summary:
INFORMATION ON VEHICLES WITH A STORED HISTORY DTC B1259 ANTENNA GROUND CIRCUIT. ( NHTSA ITEM NUMBER - 10017841 )
20. ENGINE AND ENGINE COOLING Bulletin Number: 050601026
Summary:
INFORMATION ON USE OF BOLT EXTRACTOR TOOL KIT PART NUMBER EN-47702 FOR REMOVING BROKEN CYLINDER HEAD OR MAIN BEARING CAP BOLTS ON INLINE TRUCK ENGINES. ( NHTSA ITEM NUMBER - 10017818 )
21. POWER TRAIN:TRANSFER CASE (4-WHEEL DRIVE) Bulletin Number: 050421006
Summary:
SERVICE FOUR WHEEL DRIVE (4WD) LIGHT ON, DIAGNOSTIC TROUBLE CODES (DTC) B0790, B2725, C0359. ( NHTSA ITEM NUMBER - 10017573 )
22. TIRES Bulletin Number: 000090002A
Bulletin Date: AUG 2005
Summary:
GENERAL INFORMATION REGARDING PROPER TIRE PRESSURE FOR PASSENGER CARS AND TRUCKS. ( NHTSA ITEM NUMBER - 623873 )
23. ELECTRICAL SYSTEM Bulletin Number: 030604012
Summary:
INSPECTION OF ALL RELATED WIRING HARNESS CONNECTIONS WHEN DIAGNOSING MISCELLANEOUS DIAGNOSTIC TROUBLE CODES, INTERMITTENT DRIVEABILITY CONCERNS, HARD START, NO START, INCORRECT GAUGES, INOPERATIVE AIR CONDITIONING SYSTEMS, SERVICE ENGINE SO ( NHTSA ITEM NUMBER - 10000949 )
24. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 050730018
Summary:
1-2, 2-3, 3-4, 4-5 SHIFT AND TORQUE CONVERTER CLUTCH (TCC) CHARACTERISTICS DURING COLD WEATHER OPERATION ON 4L60-E, 4L80-E OR ALLISON TRANSMISSIONS. 2005-2006 BUICK, CADILLAC, CHEVROLET AND GMC LIGHT DUTY TRUCKS. ( NHTSA ITEM NUMBER - 10017382 )
25. POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:COLUMN SHIFT Bulletin Number: 020730024A
Summary:
DIAGNOSIS OF CRACKED OR BROKEN TRANSMISSION CASE. ( NHTSA ITEM NUMBER - 634999 )
26. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 030730007A
Summary:
ENGAGEMENT TIME OF ELECTRONICALLY CONTROLLED TRANSMISSIONS IN GENERAL MOTORS VEHICLES. VARIOUS MODELS INCLUDING 2000-2006 ALL LIGHT DUTY TRUCKS. ( NHTSA ITEM NUMBER - 10005577 )
27. SUSPENSION Bulletin Number: 050307009
Summary:
VEHICLE WHEEL ALIGNMENT REQUIREMENTS AND RECOMMENDATIONS. 2006 AND PRIOR PASSENGER CARS AND LIGHT DUTY TRUCKS. ( NHTSA ITEM NUMBER - 10017370 )
28. ELECTRICAL SYSTEM Bulletin Number: 050603002
Bulletin Date: JUL 2005
Summary:
BATTERY AND CHARGING SYSTEM ELECTRICAL DIAGNOSTICS. 1997 - 2006 ALL GM CARS AND TRUCKS. ( NHTSA ITEM NUMBER - 10017463 )
29. SUSPENSION Bulletin Number: 030310007
Bulletin Date: JUN 2005
Summary:
COLD TIRE/WEATHER CHARACTERISTICS OF GM ORIGINAL EQUIPMENT V-SPEED RATED TIRES. ( NHTSA ITEM NUMBER - 10005150 )
30. EXTERIOR LIGHTING Bulletin Number: 010842001B
Bulletin Date: MAY 2005
Summary:
EXTERIOR LAMP CONDENSATION AND REPLACEMENT GUIDELINES. VARIOUS MODELS INCLUDING 1993-2006 PASSENGER CARS AND LIGHT AND MEDIUM DUTY TRUCKS. ( NHTSA ITEM NUMBER - 10005532 )
31. ELECTRICAL SYSTEM Bulletin Number: 3873
Bulletin Date: JAN 2001
Summary:
A LARGE NUMBER OF INSTRUMENT CLUSTERS HAVE BEEN RETURNED THROUGH THE WARRANTY PARTS RETURN CENTER FOR THE CUSTOMER COMPLAINT OF LOW TIRE PRESSURE WARNING LIGHT ON. ALL OF THESE CLUSTERS WERE FOUND TO BE TROUBLE FREE. SEE BULLETIN #00-00-9 ( NHTSA ITEM NUMBER - 10019453 )
32. ELECTRICAL SYSTEM Bulletin Number: 3769
Summary:
ODOMETER INOPERATIVE OR READS INACCURATE AFTER REPLACING THE IPC OR BCM. ( NHTSA ITEM NUMBER - 10018646 )
33. SERVICE BRAKES, HYDRAULIC:ANTILOCK Bulletin Number: 3724
Summary:
SERVICE VME - ABS FRONT HUB BEARING AND WHEEL SPEED SENSOR REPLACEMENT. ( NHTSA ITEM NUMBER - 10017311 )
34. ENGINE AND ENGINE COOLING Bulletin Number: 3614
Summary:
P0300 DUE TO RANDOM MISFIRES NOT FELT - POSSIBLE ACCESSORY PULLEY. ( NHTSA ITEM NUMBER - 10018577 )
35. POWER TRAIN Bulletin Number: 3609A
Summary:
HARSH 1-2 SHIFT, MALFUNCTION INDICATOR LAMP ILLUMINATED, DIAGNOSTIC TROUBLE CODE P0894 STORED IN PCM. ( NHTSA ITEM NUMBER - 10018537 )
36. SERVICE BRAKES, AIR:ANTILOCK:INTERCONNECTING ASSEMBLY(WIRING) Bulletin Number: 3601
Summary:
TRAILER BRAKE CONTROLLER WIRING HARNESS LOCATION. ( NHTSA ITEM NUMBER - 10017102 )
37. POWER TRAIN Bulletin Number: 3568
Summary:
SLIP CONDITION IN 1ST, 2ND 3RD OR 4TH/DAMAGED FORWARD CLUCTH, 2-4 BAND 3-4 CLUTCH. 2006 ALL CADILLAC, CHEVROLET, GMC, BUICK, AND CHEVROLET FULL AND MID-SIZED TRUCKS AND UTILITIES. ( NHTSA ITEM NUMBER - 10017417 )
38. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 3486
Summary:
SERVICE ENGINE SOON (SES) LIGHT DUE TO P0455 - INSPECT FUEL FILL PIPE HOUSING POSITION. ( NHTSA ITEM NUMBER - 10017103 )
39. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 3485
Summary:
ENGINE MISS ON ACCELERATION AFTER SHIFTING FROM DRIVE TO REVERSE-POSSIBLE CHARACTERISTIC. ( NHTSA ITEM NUMBER - 10017121 )
40. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 3449
Summary:
TECH 2 DOES NOT SUPPORT CAM PHASER CONTROL - TEMPORARY SOLUTION. ( NHTSA ITEM NUMBER - 10017101 )
41. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 3391
Summary:
4L60E/4L65E AUTOMATIC TRANSMISSION MAY EXPERIENCE A CONDITION OF DISTRESSED TRANSMISSION FLUID AND/OR SLIPPING, LATE OR MISSED SHIFTS IN 2ND, 3RD, AND 4TH. ( NHTSA ITEM NUMBER - 10016706 )
42. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 3136
Summary:
THE 4L60E/4L65E AUTOMATIC TRANSMISSION SLIP CONDITION IN 2ND, 3RD, OR 4TH GEAR. ALSO TO INCLUDE THE PONTIAC GTO 2005. ( NHTSA ITEM NUMBER - 10010080 )
43. ELECTRICAL SYSTEM Bulletin Number: 3785
Summary:
INSTRUMENT CLUSTER LIGHTS DO NOT DIM TO COMPLETE DARKNESS - SERVICE VME. ( NHTSA ITEM NUMBER - 10018601 )
44. EXTERIOR LIGHTING:BRAKE LIGHTS:SWITCH Bulletin Number: 3784
Summary:
STOP LIGHT SWITCH REPLACEMENT SERVICE STABILITRAK SYSTEM MESSAGE - SERVICE VME. ( NHTSA ITEM NUMBER - 10018626 )
45. TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS Bulletin Number: 3770
Summary:
TIRE PRESSURE WARNING LIGHT COMES ON INTERMITTENTLY IN THE MORNING - SERVICE VME. ( NHTSA ITEM NUMBER - 10018561 )
46. ELECTRICAL SYSTEM:WIRING Bulletin Number: 3608
Summary:
THE ABS LIGHT COMES ON DTC C0035 AND OR C0040. ( NHTSA ITEM NUMBER - 10017148 )
47. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 3694
Summary:
A ROUGH IDLE / RUNNING CONCERN MAY BE ENCOUNTERED WITH A P0014 AND / OR P0017 DTC. ( NHTSA ITEM NUMBER - 10019455 )
48. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 3694A
Summary:
ROUGH IDLE WITH DTC P0014 AND/OR P0017 - INSPECT CAM ACTUATOR SOLENOID SCREENS AND CRANKSHAFT END PLAY. ( NHTSA ITEM NUMBER - 10019427 )
49. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 3170A
Summary:
HARSH 1-2 SHIFT. ( NHTSA ITEM NUMBER - 10010577 )
50. ENGINE AND ENGINE COOLING Bulletin Number: 3221C
Summary:
SERVICE ENGINE SOON LIGHT DUE TO A P0171 DIAGNOSTIC TROUBLE CODE. ( NHTSA ITEM NUMBER - 10011666 )
51. ELECTRICAL SYSTEM:WIRING:FRONT UNDERHOOD Bulletin Number: 3508C
Summary:
SES LIGHT AND REDUCED ENGINE POWER MESSAGE WITH DTCS P0030, P0036, P0135, P0141, P1682, AND P2101 - INSPECT POWERTRAIN RELAY OPERATION. ( NHTSA ITEM NUMBER - 10018910 )
52. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS Bulletin Number: 3338A
Summary:
DRIVE BELT NOISE - ADJUST OR REPLACE IDLER PULLEY BRACKET. ( NHTSA ITEM NUMBER - 10017089 )
RYD
03-25-2006, 05:11 AM
Wow, list is almost too long to be useful.
S.
03-25-2006, 11:29 AM
Understand the difference between GM issued bulletins, and the types of bulletins, and preliminary investigation reports.
Actual issued GM bulletins have a nine digit number, sometimes with an alpha revision after the number. In addition, some of these so-called bulletins are not technical bulletins, but informational bulletins.
For example 050601026, here is the actual GM bulletin heading:
Subject: Information on Use of Bolt Extractor Tool Kit Part Number EN-47702 for Removing Broken Cylinder Head or Main Bearing Cap Bolts on Inline Truck Engines #05-06-01-026 - (09/12/2005)
Note, it is about how to use a new TOOL KIT, release for dealers. It is not particular to H3's and is for any engine using aluminum heads.
Bulletin 050089060 is a composite bulletin issued by GM for ALL vehicle lines. It is nothing more than a list of the bulletins available for ALL GM vehicles, including Saturn/Saab. H3s may not even be listed in this bulletin. This type of bulletin list is issued weekly.
Bulletin 000604033 is a bulletin that describes I/M testing requirements for states and also includes all GM vehicles.
The four digit bulletins such as 3724 are preliminary investigation on front hub/bearings that have been returned to the warranty parts center, and have been found NOT TO BE THE PROBLEM. The problem was the speed sensor, therefore, it is notifying the dealer and the technician to replace the correct part.
Hell, bulletin 990940005B tells you belt extenders are available for large people who require a seat belt extender.
Some of the four digit so-called bulletins, contain diagnosis tips on subject TAC has noted, and are there to help the technician fix it right the first time. Some of the four digit so-called bulletins are requests from GM to the dealer, that if they find a problem mentioned in the PI, to call and an engineer will be dispatched, or the part must be replaced as one assembly and returned untouched.
So far, there have been only 18 technical bulletins issued by GM for the H3. One of these bulletins should not have been issued, 02-06-04-015A, which explains how to properly connect side terminal battery cables (H3 has only top terminal), and I made note of this when the bulletin was routed, but they did not listen to me.
So, this long list can be very misleading. In addition, just because a bulletin is issued, it does NOT mean the problem will be in your vehicle. Of the 18 tech bulletins GM has issued on the H3, I have had only one problem.
GM also issues hundreds of warranty informational and procedures, along with straight informational and exchange program bulletins ranging from how to submit a warranty claim, to how to obtain an XM module or radio through a third party supplier.
03-25-2006, 11:31 AM
This is the actual complete list of TECHNICAL Bulletins issued for Hummer H3. Some of these bulletins include other car lines, some are standard issued bulletins such as removal of rail dust.
I believe I left out the bulletin that talks about the side battery terminal, since it really does not apply to H3s.
Window Outer Belt Strip Ends are Glossy (Wash Molding) #05-08-111-004A - (Jun 16, 2005)
Window Outer Belt Sealing Strip Ends Are Glossy (Wash Molding)
2006 HUMMER H3
Engine Rough Idle During Initial Warm-Up After Cold Start and Diagnostic Enhancements for DTC P0507 (Reprogram PCM) #05-06-04-053 - (Aug 25, 2005)
2006 HUMMER H3 with 3.5L Vortec Inline 5 Cylinder Engine (VIN 6 -- RPO L52)
Built Prior to VIN Breakpoint 68125462
Trailer Park Lamps, Turn Signal, Stop Lamps or Trailer Brakes Inoperative (Tie Strap Trailer Wiring Harness to Trailer Hitch) #05-08-42-012 - (Aug 31, 2005)
2006 HUMMER H3
Built Prior to VIN Breakpoint 68104782
Service Engine Soon (SES) Light On, Diagnostic Trouble Code(s) (DTC) P0442 Small Evaporative Emissions (EVAP) Leak and/or P0455 Large EVAP Leak (Reposition Fuel Filler Housing Seal) #05-06-04-055 - (Sep 2, 2005)
2006 HUMMER H3
Service Four Wheel Drive (4WD) Light On, Diagnostic Trouble Codes (DTC) B0790, B2725, C0359 (Reprogram Transfer Case Control Module (TCCM)) #05-04-21-006 - (Sep 14, 2005)
2006 HUMMER H3 with Borg Warner Transfer Case (RPOs NR4 or NR6)
Built Prior to VIN Breakpoint 68139888 (with RPO G94) or 68140143 (without RPO G94) - Off-Road Suspension Package
Cloudy Spot in Paint After Protective Covering is Removed (Heat Area) #05-08-51-005 - (Sep 21, 2005)
2005-2006 GM Passenger Cars and Trucks
2005-2006 HUMMER H2
2006 HUMMER H3
Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative (Verify and Repair Source of Voltage Loss in Transmission Solenoid Power Supply Circuit) #01-07-30-002E - (Sep 23, 2005)Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative (Verify and Repair Source of Voltage Loss In Transmission Solenoid Power Supply Circuit )
2006 and Prior GM Passenger Cars and Light Duty Trucks
2005-2006 HUMMER H2
2006 HUMMER H3
with 4L60-E, 4L65-E, 4L80-E or 4L85-E Automatic Transmission (RPOs M30, M32, M33, MT1, MN8)
Door Ajar Lamp On, Chimes Sound or Door Locks Cycle While Driving (Adjust Swing Gate Striker) #05-08-66-006 - (Oct 11, 2005)
2006 HUMMER H3
Condition
Some customers may comment that the "Door Ajar" lamp comes on, chimes sound, or door locks cycle while driving.
Diagnostic Trouble Code (DTC) P0757 Set, Service Engine (SES) Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) #01-07-30-038C - (Oct 12, 2005)
Diagnostic Trouble Code (DTC) P0757 Set, Service Engine Soon (SES) Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris)
2003-2006 HUMMER H2
2006 HUMMER H3
with 4L60-E/4L65-E Automatic Transmission (RPOs M30/M32)
This bulletin is being revised to add model years and models and change the part number. Please discard Corporate Bulletin Number 01-07-30-038B (Section 07 - Transmission/Transaxle).
Tail Lamp Housing Separates from Tail Lamp Retainers (Replace Tail Lamp Housing Retainers) #05-08-42-017 - (Nov 11, 2005)
Tail Lamp Housing Separates from Tail Lamp Retainers(Replace Tail Lamp Housing Retainers)
2006 HUMMER H3
Built Prior to VIN Breakpoint 68122692
Bumps or Rust Colored Spots in Paint Due to Rail or Iron Dust (Remove Rail Dust) #05-08-51-008 - (Nov 22, 2005)
1994-2006 GM Passenger Cars and Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
2005-2006 Saab 9-7X
This bulletin is being revised to change model year usage. This bulletin cancels and supersedes Corporate Bulletin Number 43-17-01B. Please discard Corporate Bulletin Number 43-17-01B (Section 08 -- Body and Accessories).
Door Latch Freezing In Cold Temperatures (Apply Super Lube) #05-08-64-002A - (Dec 19, 2005)
Door Latch Freezing in Cold Temperatures (Apply Super Lube)
2005-2006 Passenger Cars and Trucks
2003-2006 HUMMER H2
2006 HUMMER H3
This bulletin is being revised to add models and model years. Please discard Corporate Bulletin Number 05-08-64-002 (Section 08 - Body and Accessories).
Low Tire Pressure Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) #05-03-10-003A - (Dec 19, 2005)
Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant)
2003-2006 HUMMER H2
2006 HUMMER H3
with Cast Aluminum Wheels
Ticking Noise From Radio Speakers (Check for DTCs and Replace Radio, If Necessary) #06-08-44-001 - (Jan 4, 2006)
"Ticking" Noise from Radio Speakers (Check for DTCs and Replace Radio, If Necessary)
2006 HUMMER H3
with UB0, UC6 or US8 Radio
Built Up to and Including VIN Breakpoint 68195100
Sunshade (Visor) Vanity Mirror Bulb Inoperative (Replace Vanity Mirror Bulb Only) #06-08-42-002 - (Feb 9, 2006)
2006 HUMMER H3
OnStar Generation 6 (Digital) System Inoperative/Has No Power, LED Light Not On (Remove/Reinstall OnStar Fuse and Replace VCIM or Follow SI Diagnostics) #05-08-46-001B - (Feb 13, 2006)
OnStar® Generation 6 (Digital) System Inoperative/Has No Power, LED Light Not On (Remove/Reinstall OnStar® Fuse and Replace VCIM or Follow SI Diagnostics)
2004-2006 HUMMER H2 prior to VIN 6H108876
2005-2006 HUMMER H2 SUT prior to VIN 6H108876
2006 HUMMER H3
with Digital Gen 6 OnStar® (RPO UE1)
Malfunction Indicator Lamp (MIL) On, DTC P0894, Harsh 1-2 Shift w/4L60-E, 4L56-E, 4L70-E Automatic Transmission (Test/Replace Torque Converter Clutch (TCC) Enable Solenoid/Harness, Auto Trans Wiring) #06-07-30-007 - (Feb 28, 2006)
Malfunction Indicator Lamp (MIL) On, Diagnostic Trouble Code (DTC) P0894, Harsh 1-2 Shift with 4L60-E, 4L65-E, 4L70-E Automatic Transmission (Test and Replace Torque Converter Clutch (TCC) Enable Solenoid / Harness, Auto Trans Wiring)
2006 HUMMER H2
2006 HUMMER H3
with 4L60-E/4L65-E/4L70-E (RPOs M30/M32/M70) Automatic Transmission
03-25-2006, 09:40 PM
And I thought I found something interesting...
THANKS f5 for correcting/straighting me out !!!
RYD
