Old 12-28-2005, 07:34 PM
McHummer's Avatar
McHummer McHummer is offline
McHummer is off the scale
Just had a Pioneer AVIC-D in dash GPS system installed. Here is the wrinkle... you can only enter/change destinations while in park and with parking brake engaged. I did some Googling to see how to override the parking brake hookup and found out that it also is tied to your speedometer and the GPS tracking system. Meaning the system won't let you enter/change the destination if you are moving. Damn! Does anyone know how to override all that without messing up the entire system? otherwise it is a sweet system.
McHummer's Avatar
Old 12-28-2005, 07:46 PM
LoLo's Avatar
LoLo LoLo is offline
LoLo is off the scale
Not that this will necessarily help, but here is a link to the directions for overriding on the factory system...
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/9...891088431#9891088431
And, here are the override instructions for the dvd speed restrictions (which grounds the parking brake wire on the dvd system):
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/1.../199106444#199106444
___________________
05 Desert Sand H2 Adv
Old 12-28-2005, 09:08 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
I don't know about the Pioneer system, but if you have an installation manual in pdf I could take a look at it for you.
With my Kenwood it was really easy.
1) locate the parking sensor wire (green), remove it from your parking brake and just ground it.
Hope this helps
Rene
Old 12-29-2005, 05:53 AM
rodster rodster is offline
rodster is off the scale
I understand the first hack (being able to change nav settings while on the move) but what's this one for?
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by LoLo:
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/1.../199106444#199106444 </div></BLOCKQUOTE>
\'05 SUT
Old 12-29-2005, 05:06 PM
The AVIC-D1 requires some hardwiring to be done to allow ... watching video on the move. </div></BLOCKQUOTE>
Got it. Thanks, Phil.
\'05 SUT
